Almost 2 years ago, when I bought my first Corvette, I found a strange built-sheet in it. It was hidden under the cover of the steering column, behind the gauges. Here is the picture:
Then I started this thread.
Lot´s of comments were writen, but we didn´t find the associated owner.
So 2 years later I thought I should try it again. It´s hardly to read:
Ident.No. 332689
Date Received: 70/05/09
Model: 19467 (so it´s a convertible)
Birdgehampton
I would be glad if we could find the associated car and owner!
I'm going to have to check behind the gauges on my Vette and see if I can find it. One of the PO's installed a new fuel tank and now the build sheet is gone.
Looks like it says 454 turbo jet, so it must be for an 1970,and it's in great shape. That would be great to find the original owner. Strange that the date is backwards.....My 68 has the date in the usual order (MM/DD/YYYY) did they change that? Also date of production looks like all zeros. Maybe they do that for foreign orders?
Good of you to post this. Sorry do not mean to hyjack but new here...have searched but still looking.....how do I get access to the top of my '77 gas tank to see (snow ***** chance in hell I know) if the build sheet if still there?
I've previously seen a "1970 Corvette Registry" but the link I had archived to it no longer works. It was a listing by serial number where owners could post their info. If anyone knows if this is still in operation it might be a source to get closer to an owner.
There's a link ("Research & Resources) to provide any build sheets or other info. I'm still hoping that some day I'll get someone from out of the blue emailing me that he's got mine...
i am changing out my rear end and the rear plasitc bumper for fiberglass i can see the back and top of my fuel tank but not the front part with the rear bumper removed should the buils hseet be visible or do i have to remove the tanks to find it?
