Replacing Lower Trim Plate and E-brake cover
Old Mar 29, 2010 | 08:56 PM
RF1979C3's Avatar
RF1979C3
Default Replacing Lower Trim Plate and E-brake cover
I am getting ready to replace the lower trim plate, the lenses, and the emergency brake cover in my '79. Looking at the Assembly manual am I correct in assuming that the console side plates need to be removed first? Anyone else tackled this. It does not look hard, just time consuming. Any help is appreciated.
Old Mar 30, 2010 | 09:26 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Removing the tunnel trim will allow access to the console trim plate. They're carpeted fiberboard and have a couple of trim screws in them.
Old Mar 30, 2010 | 09:41 AM
gbvette62's Avatar
gbvette62
The console bolts to the gauge cluster, the PB cover and is also bolted to brackets on the tunnel. You can't get to these bolts without removing the side panels. There are 3 screws holding each side panel in place. A couple screws can be a bit of a pain to remove with the seats in, but it's not all that dificult.
Old Apr 7, 2010 | 09:14 PM
RF1979C3's Avatar
RF1979C3
Thanks for the help guys, I think I am going to tackle this project over the weekend.
Old Apr 7, 2010 | 11:04 PM
boatdoc's Avatar
boatdoc
For as long as it takes to pull the seats, I'd take them out. It's one of the first things I do when something goes haywire inside the car. One screwdriver in the back pocket can really ruin your day not to mention your nice leather seat cover.
To Replacing Lower Trim Plate and E-brake cover
