Is it ok to run a stock LS-5 on unleaded w/ no additives? Last time I had a car that it mattered was in the late 80's, and had a 390 Galaxie, and back then everyone thought you needed to add lead. I did a bit of research and it seems that the consensus now is that if the car isn't driven hard, that unleaded would be fine in an LS-5. Fact or fiction?
It is not ok!!!!! The valve seats from a stock cylinder head are not hardened. So you should better drive with lead additive. Maybe it will be ok if you do not add lead additive with each tank - but compare the price from the additive with the price of an engine rebuild.
If you do a search on this, you will find this one has been beaten to death dozens of times. Adding lead won't hurt your car, but it will hurt your wallet and our environment, but it's your car, so do what you want. I have been screwing around with cars from the late 60s and early 70s for 30+ years now, and have never had a problem running unleaded gas in engines of that era. When unleaded gas first came out in the '70s, the "common wisdom" was that without the lead as lubricant, the valve seats would wear prematurely. However, in about 1986 or so, leaded gas became unavailable, and we didn't see a rash of worn out heads shortly thereafter, so I think the concern was overstated to say the least. Some engines in extreme use, did and do have problems with the new fuels, but generally street engines have no issue with unleaded fuel.
I own a 1970 LS-5. I don't use any fuel additives. So far, I haven't had any problems with fuel. Be careful of snake oil salesmen.
Unless you're pulling a heavy trailer up a steep hill for hours on end, the valves seats will never get hot enough to suffer. No lead required, just an old myth that won't die.
2016 C2 of Year
2015 C3 of Year Finalist
Not only do you not need it, your spark plugs will last alot longer without the lead. Many of us have been driving our old Corvettes for MANY years with unleaded fuel with no problems. Just run the 93 octane and you will be fine. As Mike said, these myths die hard
As I posted above, I did do a search, and as you can tell from the first 2 responses, there is still uncertainty among some folks, which is why I wanted to get my own feedback on it from experts such as yourself.
The last time I dealt w/ this was in the late 80's when I was a teenager, and the consensus then was that you always had to add lead. I see now that is not the case, which is good! A buddy just picked one up, and we were curious, as neither of us have any real experience w/ pre-emissions/high compression engines.
Use any good-quality oil of the viscosity level required by your location and driving conditions. Change it at regular intervals and your engine will appreciate it. If you have a super-high-performance engine, use oil and additives that are appropriate for your engine's needs.
I have a SB base engine that is usually pampered and not abused. I use Mobil 1 full-synthetic 10W30 oil which I change once a year [or so]; but I change the filter every 2000-2500 miles.
It contains zinc, which is not added to any of the modern oils. On older flat tappet engines it is needed to aid in lubrication between the cam lobe and lifter.
Do a google seach on inc and engine oil - there are some very informative articals out there.
As for lead - add it if it makes you happy, but for normal driving you will not have isues with valve seat recession.
I have added TEL to fuel and on my car, the engine will idle smoother and I swear it runs a bit cooler.
Drawback - it fowls the plug out in 3-5K miles. Changing them plugs on an LS5 is a bitch if it has AC. The unleaded fuel will give you 4-5 times the plug life..
