Z-Bar frame bracket
Old Apr 6, 2010 | 04:26 PM
Phil Zell's Avatar
Phil Zell
Default Z-Bar frame bracket
I need a little help locating just exactly where to weld the Z-Bar bracket to the frame on my auto to manual conversion.
Any help ?
Any Pics ?
Also will need a little guidance on cutting the hole in the floor for shifter.
Great forum !
Old Apr 6, 2010 | 04:48 PM
Dustup7T2's Avatar
Dustup7T2
Terrorizing Orange Cones
I hope this image gives a better guess-timate to cross-shaft (z) bracket location, as I do not have the exact dimension readily available. Perhaps another member can offer if they have it handy.
Note the brake line clamp bolt's distance to edge of bracket (mine was clutch car new):
Here's another general image of the shifter's hole on tunnel:
I'll look to see if I have one without the boot/handle installed.
Old Apr 6, 2010 | 04:59 PM
Dustup7T2's Avatar
Dustup7T2
Not the best contrast of shifter's hole but may offer some comparison data:
Better contrast but low angle:
Hope it helps a little in getting you closer.
Old Apr 6, 2010 | 06:00 PM
BenUK's Avatar
BenUK
Maybe these photos might help?
(Ignore the missing floor )
I can take dimensions if you need them. My interior is still stripped.
Buying the rubber boot will give you an idea of the lateral position of the hole because the boot's foot is profiled to fit the curve of the transmission tunnel.
Old Apr 26, 2010 | 02:01 PM
Phil Zell's Avatar
Phil Zell
Very helpful picks
much appreciated
Old Apr 26, 2010 | 02:54 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Originally Posted by Phil Zell
Very helpful picks
much appreciated
Thanks from me too.
To Z-Bar frame bracket
