Engine Clean-up
Old Apr 8, 2010 | 10:25 PM
wheatpj's Avatar
wheatpj
Default Engine Clean-up
I have the accessories (PS Pump and Alternator) and associated brackets off the front of my engine (water pump still on). Before re-assembling I thought I might clean up the front of the engine and frame cross member with some degreaser. Any problem with hosing off the degreaser if I am careful to keep the water away electrical components?
Old Apr 9, 2010 | 12:08 AM
67tripwr's Avatar
67tripwr
I would degrease the whole thing! I have never really had any problems doing it that way.
Old Apr 9, 2010 | 03:02 AM
moose8793's Avatar
moose8793
Old Apr 9, 2010 | 07:13 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
I pressure wash my engine regularly, I just be careful not to shoot the water stream on to the carb and any ignition component, also I never pressure wash the engine when its hot and I never start it up unless its completely dry and I use a hand blower to blow off the water right after I'm done with the wash.
before :
after :
Old Apr 9, 2010 | 09:02 AM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
Hamadup
I think you did just a little bit more than wash it......
Old Apr 9, 2010 | 09:30 AM
oldsarge's Avatar
oldsarge
Originally Posted by Faster Rat
Hamadup
Just a little.......
Old Apr 9, 2010 | 09:31 AM
oldsarge's Avatar
oldsarge
I put plastic bags over the carb , distributor , coil and alt, then wash the whole thing, no problems.
Old Apr 9, 2010 | 09:33 AM
SuprJames's Avatar
SuprJames
Hamadup
I see at least hydroboost, distributor cover, and afterrmarket AC added. Sure there's more I'm missing.
This is a little more relevant. A little degreaser and paint in addition to pressure washing works wonders:
Old Apr 9, 2010 | 09:48 AM
Kevins77's Avatar
Kevins77
Man, you guys need to clue me in on this! Where can I find the degreaser that not only cleans but fuel injects and supercharges as well?
Old Apr 9, 2010 | 11:21 AM
Leung's Avatar
Leung
Old Apr 9, 2010 | 11:36 AM
7T1vette's Avatar
7T1vette
Back to the thread....
No problem using the degreaser. I don't think it will even do any harm to the wiring....except maybe get the grease off of them too. Remove the air cleaner and cap-off the top of the carb (make a plastic or wood cover that will seal it from cleaning work). That way, the carb gets cleaned, too.
Old Apr 9, 2010 | 02:39 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
Hamadup
ok .. ok .. you're right! .. but I dont have any "before" image other than that, but when ever my engine bay will be full of dust (this is my daily driver and I live in a desert) I just pressure wash it and it becomes like that, I dont use any kind of soap or degreaser ... etc, just plain pressurized water.
Old Apr 9, 2010 | 03:41 PM
rajsid's Avatar
rajsid
Hamadup
Yeah, I think he got new wing nuts for the air cleaner lid.
Old Apr 9, 2010 | 06:44 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
Old Apr 10, 2010 | 05:20 PM
wheatpj's Avatar
wheatpj
Thanks guys for the advice. more questions sure to come. i'm in the middle of a front suspension rebuild. Hope to have everything back together and clean and shiny by the end of June...that is if I don't diverge to much from my intended task.
Old Apr 10, 2010 | 10:10 PM
NJVette77's Avatar
NJVette77
Hamadup
Sure looks like he did
Old Apr 10, 2010 | 10:20 PM
Corvette.Lover's Avatar
Corvette.Lover
Very good...
To Engine Clean-up
