Accelrate and lose control
Old Apr 23, 2010 | 03:49 PM
MN-Brent's Avatar
MN-Brent
Originally Posted by czardali
ok ! Update.
The following was said was needed:
Idler:$113.40/ labor $144.50
Sway bar $19.16/ labor $59.50
Control Arm bushings(Lower) $23.85/labor $238.00
Labor -Adjust and repack bearings $70.00
Alignment $80.
so...there ya have it.$700 bucks of damage. What can I do myself?
Depending on your mechanical skills and tool set, all of this is possible in your garage. Then go get it aligned.
To be honest, these prices look pretty low. I'd be concerned your being slightly baited, as shop labor rates may be a variable in this quote.
In the end, if you are not comfortable with doing any of this, then bring it in and write the check.
B.
Old Apr 23, 2010 | 03:50 PM
shank0668's Avatar
shank0668
If you are mechanically inclined then maybe all of it except alignment.
Old Apr 23, 2010 | 03:58 PM
69autoXr's Avatar
69autoXr
All of it, including alignment.
Old Apr 23, 2010 | 04:19 PM
Shark Racer's Avatar
Shark Racer
If you're a skilled mechanic, you can do all of it yourself. Everything listed is relatively straight forward, except for the LCA bushings which would require a bit more heavy equipment.
Old Apr 23, 2010 | 04:26 PM
redman76's Avatar
redman76
St. Jude Donor '09
Originally Posted by markids77
Write the check, and drive carefully.
OMG
Old Apr 23, 2010 | 05:01 PM
blueray72's Avatar
blueray72
If you bent the lower a arm near the bushing..you'll get the old one out......but getting the assembly back together won't be easy...and may not happen at all.
write the check and enjoy.
