You need to describe more of what it does when you accelerate and how you hit the curb. If it seems like the rear end is shifting to one (or both!) sides you might have damaged your trailing arms or TA bushings. If you hit the front at any speed it could have damaged a lot of stuff.
Agreed, if your car is a handful to drive after your mishap, please do us all a favor and fix what's wrong before you make your car worse, or worse yet you hurt yourself or someone else.
I'm guessing you "popped" the retainer clip off the rear side yoke of your IRS, Will require teardown of differential to find and can also destroy parts inside if you ignore it.
That's a good guess. Mine is a broken U-joint on one of the half shafts.
My wife once did this in a POS Mazda 626, and bent her front lower control arm. It was easier to just replace the whole side, strut-steering knuckle and control arm as some items were press fit.
Sounds like you won a trip to a local Corvette and/or alignment shop, unless you can figure it out for yourself what is damaged/not damaged.
