1980 corvette AC/Heat problem
Old Apr 24, 2010 | 07:36 AM
warrior2291's Avatar
warrior2291
Default 1980 corvette AC/Heat problem
Hi I own a 1980 corvette L-82 model.
I have just about completed the restore on most of the car. I have a problem with getting the AC to blow out the vents instead of the floor. I replaced the whole AC system in the car and converted it to R134.
I replaced the condenser, the radiator, the pressure switch, the compressor and the drier. I have all new oil .
I noticed when I select the AC or Heat switch I do not get a high volume of air flow out of the vents at all. I get it all out the floor vents and even then it is not very strong. I replaced the blower motor and basket, the resistor switch, the relay, I even replaced the fan switch in the controller on the center console?
Does any one have an idea what it could be? I have been told that the vacuum rubber hose line that operates the vacuum switch could be bad. Another words the switch could be bad.
Does any one know where I can get this switch???
Any help is greatly appreciated.
Old Apr 24, 2010 | 08:15 AM
MN80Vette's Avatar
MN80Vette
This might be what you are looking for:
Air Conditioning Control
You can shop around for the best price.
Old Apr 27, 2010 | 01:22 PM
warrior2291
I think you are right thank you for the tip.....
Old Apr 27, 2010 | 02:48 PM
markdtn's Avatar
markdtn
Most likely the vacuum switch on the control is bad and/or come apart. It fits other GM cars and used to be available from GM, not sure anymore.
Old Apr 27, 2010 | 04:10 PM
spedaleden's Avatar
spedaleden
with above. Also make sure you don't have a pinched line coming from the engine. No vacuum, no vent movement
Old May 4, 2010 | 11:15 AM
warrior2291
Originally Posted by spedaleden
:i agree: with above. Also make sure you don't have a pinched line coming from the engine. No vacuum, no vent movement
good call found broken switch in controller and replaced also found pinched line fixed both work great !
Thanks to all!!!
To 1980 corvette AC/Heat problem
