Paint for frame and underside
Old Apr 24, 2010 | 05:30 PM
dmeesq's Avatar
dmeesq
Default Paint for frame and underside
What kind of paint do you use for your frame, differential, ect. and what color?
Old Apr 24, 2010 | 06:20 PM
Alan 71's Avatar
Alan 71
Hi D,
There are lot's of colors of paint and different kinds/colors of plating under there.
For the two you asked about...the frame is semi-gloss black and the dfferential was natural cast iron. Many people paint the differential and other cast iron parts with a paint called Cast Blast rather than leave them bare.
The Eastwood Co. sells lots of chassis and running gear paints... check out their web-site.
Regards,
Alan
Old Apr 24, 2010 | 07:43 PM
Mark G's Avatar
Mark G
Alan 71 had some good advice. What I do is use regular black urethane-based black (with hardner added) and add in some flattening agent. That produces a nice semi-gloss with better chip resistance than a regular enamel paint. It takes a little more effort to ensure you get the ratio so you have the 'right' level of flattness.
Good luck,
Mark G
Old Apr 24, 2010 | 08:00 PM
mds3013's Avatar
mds3013
Here is the before and after of my halfshafts. Paint on shafts is Plasticoat rebuilders cast gray. They also make an aluminum color. mds...
Old Apr 24, 2010 | 08:32 PM
jordan89's Avatar
jordan89
Eastwood does make some good products. I'm about to order some paint for my suspension parts, and am also thinking about ordering Zero Rust for the chassis and underbody.
Old Apr 25, 2010 | 02:07 PM
stinger12's Avatar
stinger12
Every part was sandblasted and powdercoated. The only part with paint is the pinion yoke.
Old Apr 25, 2010 | 09:31 PM
ssenay72's Avatar
ssenay72
por 15
Old Apr 26, 2010 | 12:58 AM
Steve COSD's Avatar
Steve COSD
John Deere make a great paint that is the correct sheen and tough. It is called Blitz Black. Got this tip on the forum
Old Apr 26, 2010 | 03:27 AM
jimo's Avatar
jimo
Originally Posted by ssenay72
por 15
Old Apr 26, 2010 | 04:04 PM
TWINRAY's Avatar
TWINRAY
Regards,
Alan
Cast blast for the rear and Eastwood Satin on the frame
The leaf spring I did with Krylon Gray and the half shafts, Cast Blast.
To Paint for frame and underside
