Brake help
Old Apr 25, 2010 | 06:20 PM
BLOhio's Avatar
BLOhio
Default Brake help
ok in the fall i replaced all 4 calipers blead the brakes had good pedal...Drove the car Friday and brakes felt good....Saturday morning went out and pedal is really soft but brakes still work but pedal goes to floor....I checked fluid and its full no leaks anywhere...Any ideas? Thanks for any help...Its a 1979 if it makes a difference..
Old Apr 25, 2010 | 06:45 PM
Duke94's Avatar
Duke94
Too much rotor runout. Causes the piston to move in/out and suck air. You may have to shim the rotors to reduce the runout. Were the rotor turned?
Gary
Old Apr 25, 2010 | 06:52 PM
71coupe454's Avatar
71coupe454
If the pedal pumps up good or not, holds or bleeds off, might help narrow it down..
Old Apr 25, 2010 | 07:55 PM
BLOhio's Avatar
BLOhio
I replaced all the rotors when i did the calipers...Yes the pedal does pump up and hold...but after you let off and hit them later it soft again..
Old Apr 26, 2010 | 03:58 PM
Duke94's Avatar
Duke94
If you have a long pedal from just sitting (not driving) then it's not rotor runout. Sounds like you still have air in the system.
Gary
Old Apr 27, 2010 | 12:22 AM
BLOhio's Avatar
BLOhio
OK so i think i will bleed the brakes again before changing the master cylinder. Thanks for everyones help..I will update tomorrow
To Brake help
