Fuel gauge
Old Apr 26, 2010 | 11:21 PM
ozzyrulesme's Avatar
ozzyrulesme
Default Fuel gauge
MY gas gauge dose not work. replaced the sending unit , but still don't work. Any one have an answer? thanks for the help!
Old Apr 26, 2010 | 11:29 PM
mds3013's Avatar
mds3013
Check Willcox's site. Under repair and install help. It has the best info on gauges and how they work on Forum. mds...
Old Apr 26, 2010 | 11:49 PM
...Roger...'s Avatar
...Roger...
http://willcoxcorvette.com/instructi...68-76_ver7.pdf
Old Apr 27, 2010 | 02:18 AM
7T1vette's Avatar
7T1vette
Possible causes: bad sender (apparently not your problem); bad wiring/ground for sender; bad connections on wiring/ground to sender; break in the signal wire running to the gauge; bad wiring/ground at gauge; bad connections to wiring/ground for gauge; no 12 vdc power getting to gauge; defective gauge.
Note: Always test the wiring, connections, and power/ground sources before replacing components. Rule out the simple stuff, then test the components. Replace only the defective ones.
You should be able to test the gauge/wiring/connections by removing the signal wire from the sender, then turn ignition to ON [engine OFF]. With signal wire not touching anything, the gauge should swing full-scale one direction; when the sender wire is touched to electrical ground [one that actually links with the - battery line], the needle should swing full-scale the other direction. If all that works back to the end of the signal line at the fuel tank, then your problem has to be a defective ground wire/connection at the tank or a defective sending unit [even if it is 'new'].
Old Apr 27, 2010 | 07:46 PM
Schaggy's Avatar
Schaggy
Not sure about your car, but my '72 was missing a resistor that contacted both posts on the gas gauge. Replaced that and everything came up roses.
Good Luck!
Old Apr 27, 2010 | 10:56 PM
ozzyrulesme
Thanks i will check willcox site. I forgot about the help pages on there site. thanks again!!!!!!!!!
Old Mar 25, 2014 | 08:46 PM
ozzyrulesme
Hi,
Ok 4 years go by now after replacing the sending unit, which fixed the issue. Now the gas gauge don't go past 1/4 of a tank when full ... Why.????
Old Mar 26, 2014 | 09:39 PM
mds3013's Avatar
mds3013
I can tell you why mine did a similar thing. There is a resistor on the back of the gauge that was not making contact through itself to the contacts of the gauge. I am not sure if your '74 is even close to my '77 but looking at Willcox's info for your car is where I would start. Maybe start a new thread for this new problem. mike...
To Fuel gauge
