The most likely problem is that the "check valve" in the vacuum feed line (round metal piece with one fitting on the 'input' side and two fittings on the 'output' side) has failed. Remove it from the vacuum lines and suck on the 'inlet' fitting while you hold a finger over one of the 'outlet' fittings. If the valve is working properly, you should not get any air through it when you suck on it. Try this with each of the output fittings. If there is any leakage, replace it. It is a good idea to replace the [white plastic] filter in that line while you are at it.
Thank you for the help. I know exactly the valve you are speaking of. I took it off before and "blew" through it rather than "sucking" on the inlet. I will try that.
However, there is nothing on the hose line between the "check valve" and the engine. I have a chart that shows there probably should be a filter on that line.....Do you agree for a 1970 Vette that a filter should be there and is it necessary function properly?
Yes the white thing is a filter,and yes it will function fine without it but you should have the filter in place to protect the check valve from intake fumes and soot.
Sorry, I'm not sure I get this.................is the filter "in" the check valve or is it a seperate part the should exist between the check valve and the engine?
The filter is a separate device. From the manifold connection there is a short piece of hose, then the filter, then another short hose, then the check valve. From there, it heads toward the wiper door system, vacuum reservoir, and headlights. I am not absolutely sure about the purpose of the filter...whether it is to protect the check valve at engine start or shut-down, or whether it is to prevent any debris or degrading hose particles from getting into the intake manifold. Anyway, that's how the system is set up on early 70's cars.
I noticed that my car was missing the filter also so I ordered a new one as well as a new check valve. I have not installed the filter yet, but after I changed out the check valve the vacuum system no longer works - the headlight doors and wiper door both go up and stay up as soon as I start the engine. Everything worked fine previously, and worked fine again after I put the old valve back in. I am assuming the new valve is defective, unless the old valve was masking some other problem. Any other ideas?
To clarify: Suck on the single-ported side of the check valve and there should be flow through the check valve. That simulates manifold vacuum "sucking" air out of the headlight/wiper door/HVAC vacuum system when your start & run the engine.
Try to blow through the check valve on the single-ported side of the check valve and there should be NO flow through the check valve. That simulates manifold pressure returning to atmospheric pressure after shutting the engine down.
Whether you 'suck' and get airflow or you 'blow' and don't get airflow...it's all the same, except that with blowing through it, you never know if it is going to seal with vacuum applied. You just have to get your directions right.
Yours sounds like a case of 'if it ain't broke don't fix it'. The new filter can't hurt anything since it is a pass-through device, but it does sound like you bought a defective check valve. What are the chances of that happening these days?
Interesting.....the 2 ports on the one side connect together,the small one must be plugged,see if blowing through the large one allows air to come out the small one.
