Alternator Numbers
Old May 3, 2010 | 03:40 PM
427basketcase's Avatar
427basketcase
Default Alternator Numbers
Did the alternators on C3 Corvettes have a specific part number, or are they just date coded?
Old May 3, 2010 | 03:42 PM
toddalin's Avatar
toddalin
Both.
Old May 3, 2010 | 04:10 PM
Alan 71's Avatar
Alan 71
Hi 427b,
Here's an example:
1100950.... #
1A7 .... Jan. 7, 1971
42 amp
12 V neg
Regards,
ALAN
Old May 3, 2010 | 04:30 PM
Frogday's Avatar
Frogday
Originally Posted by Alan 71
Hi 427b,
Here's an example:
1100950.... #
42 amp
12 V neg
Regards,
ALAN
Hi Alan,
What did you use to clean your alternator? Is it painted?
Old May 3, 2010 | 05:07 PM
Alan 71's Avatar
Alan 71
Hi FD,
The case was in pretty good condition to begin.
I used a brass wire wheel on my bench grinder at a slow speed. For some reason the front part of the case came out looking a bit different than the rear part??
The case has a LITTLE bit of clear on it to stop it from oxidizing.
Regards,
Alan
Old May 3, 2010 | 05:27 PM
427basketcase
Thank Alan, That's exactly what I was looking for.
BTW Nice looking alternator
Old May 3, 2010 | 08:26 PM
Mark G's Avatar
Mark G
Not to hijack this thread, but does anyone know if later C3's also have date-coded alternators? The one off my 81 has stampings on the front face partially under the fan blades. The numbers are:
1105 552 85A
9203 12v Neg
Any way to ID it? I suspect it's a GM replacement.
Thanks in advance.
Mark G
Old May 3, 2010 | 09:41 PM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
They also had broadcast codes black ink stamped on them. In the case of my 71 alt 1100544, 61Amp, 1C8 (March, 8th 1971), 12V Neg, the broadcast code is RH & A. Over time these ink stamped codes would disappear.
Old May 4, 2010 | 09:19 PM
Mark G's Avatar
Mark G
Does anyone know if later C3's also have date-coded alternators? The one off my 81 has stampings on the front face partially under the fan blades. The numbers are:
1105 552 85A
9203 12v Neg
Any idea on these number?
Thanks in advance,
Mark G
To Alternator Numbers
