Chev/Vet Wheels
Old May 4, 2010 | 08:04 PM
patto's Avatar
patto
Default Chev/Vet Wheels
Are the standard alloys on an '80 vet a standard 'Chev' description wheel set out.
My measurements read 15"x8"x4.25"backspace with a 2.75" centres on the nut spacing (this measurement in a straight line).
I keep getting told vets are slightly different if looking for new wheels?
Old May 5, 2010 | 10:25 PM
GUSTO14's Avatar
GUSTO14
The Corvette wheels use a standard Chevy bolt pattern and will therefore fit the vast majority of Chevy's of the era. The backspacing and even wheel width may be an issue on some Chevy's, but won't be for a majority of them.
You might want to borrow a Corvette rally wheel from someone (they seem to be readily available) and see how it fits clearance wise. One good thing is you should not have problems clearing most Chevy disc brake setups.
Good luck and hope it helps... GUSTO
Old May 6, 2010 | 07:33 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I'm a little confused...Are you looking for different wheels for your Corvette, or wanting to use Corvette wheels on a different car?
As "Gusto14" has already mentioned, the 'Vette wheels are the same bolt pattern (5x4.75") and centerbore as most of the GM wheels of that era. The backspacing is also fairly close to the other GM wheels, so there's a lot of possibility of interchanging. (most of the 7" GM wheels were either 4, or 4.25" backspacing)
Back in the 70s, I ran the 15x8 'Vette Rallys on a number of my cars, as a "low buck" way to get wider wheels.
To Chev/Vet Wheels
