L48 / l82
Old May 16, 2010 | 08:56 PM
Stuey1975's Avatar
Stuey1975
Default L48 / l82
Is there a way to take a L48 and make it a L82?
Got a friend with a 1977, he wants to boost its power but didn't know the best way.
Anyone had any experience upping the hp from 180 to something with a little more juice other than doing a engine swap?
Old May 16, 2010 | 09:36 PM
72LS1Vette's Avatar
72LS1Vette
One of the top end kits from Summit or Jegs should give him a big HP boost. The main difference between the L48 and the L82 is that the L48 is a 2-bolt main bearing cap so he would probably want to keep the HP below 400 to be safe. The 77 L82 was only 210 HP so he could probably get that number with just a cam and some carb/ignition tuning.
Rick B.
Old May 16, 2010 | 09:52 PM
'75's Avatar
'75
In my opinion, the best bang for the buck is installing vortec heads and a Summit 1103 cam. It's a good running combo and not too expensive. I'm told you will end up with around 325 hp. I did it and I love it.
Old May 16, 2010 | 10:22 PM
jordan89's Avatar
jordan89
with both of the guys up there. A top end kit will really wake things up. If he has the budget for a kit with aluminum heads, go for it.
Old May 16, 2010 | 10:24 PM
Tom73's Avatar
Tom73
Add 4-bolt mains, L82 cam, and install big valves in the heads.
Basicly the intake, heads (except valve size), block (except main bolts), and exhaust manifold were the same. Used the same carb and dist but with different config.
On The 73 Spot I have a listing of the differences in the L82 and L48 for the '73 year: http://www.73spot.com/index_stats_files/s_compair.htm
Old May 16, 2010 | 10:29 PM
Rmorgan&11's Avatar
Rmorgan&11
and if you do heads , go full roller valvetrain .....
L-48 also has lower compression pistons than the L-82 , and I believe they are cast not forged
so no matter what you throw on top..... the 2 bolt mains should be good ....unless you add a nitrous kit....
Old May 16, 2010 | 10:54 PM
Tom73's Avatar
Tom73
Should have mentioned that, the L82 uses forged pistons with 9.0 to 1 compression. Also uses forged crank.
tom...
To L48 / l82
