converting it to convertible
Old May 28, 2010 | 09:27 PM
milo30's Avatar
milo30
There are several threads on this. Just run a search. You can get your fiberglass at http://www.acivette.com/ .
A soft top frame runs around $1800. used or reproduction. A hard top can be gotten for around $500. You have to do some modifications in the tub for the rag top to fold down.
Everyone has a different idea of what is different on a coupe or convertible as far as supports. I know there are braces under the dash. This is the first I have heard about different doors, but the window glass is different for sure. I have also talked to a company that has done these conversions for years and they swear that there is a brace that has to go from the rear of the doors to the back of the tub under the deck but I haven't seen that one anywhere.
I've seen a few rear decks on ebay at good prices lately but they won't ship them. Some of the parts to finish it out are hard to come by.
You'll notice in some old threads that the chrome is not available for the window but I just saw a month ago that a company has started reproducing that now.
Old May 29, 2010 | 02:40 PM
vcb's Avatar
vcb
thanks
I saw many info on it, they also put a brace across the rear clip right by the tank.
what is the best glass to put the rear clip?
Old May 29, 2010 | 02:55 PM
Earthquake Driver's Avatar
Earthquake Driver
From: I buy all my days at the same place where the girl sells her nights
Here's one for sale
http://philadelphia.craigslist.org/cto/1699089186.html
Old Oct 10, 2010 | 07:25 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Originally Posted by paul 74
A/C, ductwork, heater box, and bar.
In my search to obtain the convertible cowl bracing it would seem this evolved during the C3 run, particularly that later models may not have included the brace saddle on the trans hump, and may have only had 4 struts. Trying to figure out if the saddle is necessary, and (if not) how the struts would otherwise attach in a '78. Might you be able to shed some light on this, and perhaps share an AIM illustration?
TIA
Old Oct 11, 2010 | 03:25 AM
WESCH's Avatar
WESCH
Hi
The cowl bracing only started in the later 68 run, hence early 68 convertibles do not have this.
It is not so required.
If you install it, you do need the saddle, otherwise you do not find any steel attachments points on the tunnel.
Just forget about this cowl bracing and concentrate on the other stuff. It is difficult enough.
Rgds. Günther
Old Oct 11, 2010 | 12:11 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
VCB Before you start sawing and hacking, purchase any of the assembly instruction manuals (AIMs) for 68-75 when convertibles were in production. Take a look at the differences in convertible and coupe construction. Purchase the 80 AIM so you will have an idea of how your car is put together.
The AIMs will show how the rear surround panels are bonded to the underbody.
If you think things through and remove your existing body panels along the factory bonds, you can probably sell your panels to someone who needs them and get a little of your money back.
81 underbody and surround panel bonding areas shown. Your 80 will be similar.
Note fender bonding lines.
Old Oct 11, 2010 | 11:28 PM
HobbyPoor's Avatar
HobbyPoor
Its not a bad job at all if you can do some paint and body and have a vert to reference along the way. Heres my 81 and I did no extra bracing with it and have had zero problems.
Old Oct 11, 2010 | 11:38 PM
TheSkunkWorks
Originally Posted by WESCH
Hi
Rgds. Günther
Your being someone who went thru finding and adding this bit of kit I really do appreciate your feedback. Agree it's looking fairly difficult, and as I haven't scored the saddle as of yet, I'm certainly beginning to have some doubts and may very well end up redesigning the trans x-member sooner than later.
And, thanks Paul for chiming in on my related thread. FWIW, my apologies to the OP for the sidebar. Great thread going here! Almost makes me want to chop my top or do the targa thing myself.
