What will you do different next time?
Would never buy a car already done and think it is cheaper
You all most always have to redo things as they are Bubba or just not the way I want them! Yea I know there are good cars out there, but you really never know how good or bad they are until you have them a while.
Get a bigger wad of cash that would:
1. upgrade garage insulation for tighter environment
2. refinish concrete floor
3. install a natural gas shop heater
4. route water & drain
5. install 2-post lift
6. have more fun bleeding & healing
The rest are just details.
Before I tackle my next one (hopefully a solid axle), I will enlarge/renovate/upgrade my garage. And add a lift.
But I said that too before I found a 65 project that I just started on, and I'm still in the same garage
1. I did many parts twice - blasted then painted - blasted then powder coated - ON ALL 3!!!!!
2. Built the bigger garage when I had the opportunity (and the wife's seal of approval).
3. I never would have taken 2 cars apart at the same time.
4. Been more decisive on what I wanted out of this hobby. NCRS, Just Pretty, Just a driver. Spent too much money on items that ended up not being the right direction for me.
Common themes that we all share;
Start with the right car,
Double your expected budget (triple?),
Have an adaquate place to work,
Don't cut corners trying to save money because your going to do it over the right way eventually.
What a kick. This forum is part of the hobby experience.
Blain
Well - after mine was sitting for years, I decided to fire it up (that worked good), then replace the radio and one small tear in the passenger seat. Well that did not go well.....
The whole interior ended up coming out so I could use Cool Car Ceramic. Then while I was at it, I took all the chrome off for painting.
I also noticed my alternator wiring was nasty - so I pullled the alternator and set it on the fender to tinker away....... hmmmm... I figured that was not a good idea.... so [[picture this]] with alternator in both hands at my waist looking around the garage for a place to set it while I worked on it. I set the alternator down and began rebuilding my garage. That was an extra 14 months or so.
Then the engine bay looked bad, so I pulled the motor to clean up the engine bay. Well, since the motor was out and I had to run airplane fuel to deter detonation, I had the motor rebuilt (read: don't rebuild a 427/435 - get a crate motor). Then the body came off and I felt it necessary to take every thing off the frame to rattle can - which turned into being powder coated.... so then I bought new trailing arms, suspensions (as I surely did not want to re-do this again). Then I upgraded to Electric Fans, Alum Radiator, Vintage Air, newer alternator, etc, etc, etc...
Oghh - somewhere in there 3-4 years was paying body shops to do nothing. Including putting 1/4" - 1/2" bondo ALL over my car. So it was then (while pulling the 2x4 splinters from my backside) that I decided to get back into the body business (for my car) and remove all that bondo - which I did. After 3 re-sprays - it is painted.
Did I note that I pi$$ed my neighbors off with my temporary plastic wrapped paint boothe, my sanding in the driveway.
Did I mention I bought all new wiring harnesses too, new tires, sandblasted my wheels, rebuilt all gauges, new weatherstripping, new carpet, convert to power brakes, Dynamat, side exhausts and covers, offset T-arms, new bumpers, bought new tools, body hoist on ceiling, spent wayyy too much money, time, heartache.......
My 2 cents would be to....
Invest in many ziplock poly bags, a good electronic camera and a magic marker. Clearly catalog and be decriptive about where the dang parts /bolts go back on the car. Realize a good body shop is hard to find. Realize that the body off committment comes first - not midway in the project.
All said, I do have a list of things I did right - can we start a list?
Used Corvette Forum for assistance (met some really good people)
Did a 69 Chrome bumper car
DeWitts Radiator, Spal Fans
Motor went to over 500hp and runs on pump gas
A/C that works
Lectric Limited Harnesses
Not giving my poopy attitude neighbors a ride in my car
Laying down 2 blacker than black rubber marks in front of my poopy neighbors house at 3:00am
[/IMG]
