1980 Ignition Key buzzer switch
Old May 22, 2010 | 05:50 PM
C3Paul's Avatar
C3Paul
Default 1980 Ignition Key buzzer switch
Hi,
My Warning buzzer keeps buzzing, with or without the Ignition key in the lock.
I have checked everything and found the problem to be the electrical connection going to the steering column.
I have ordered a new switch and am ready to replace the old one. http://www.ecklers.com/product.asp?p...&dept_id=1168#
However,
Where is this switch located?
And
How do I replace it?
Thank you
Old May 22, 2010 | 07:24 PM
oldsarge's Avatar
oldsarge
It is in your steering column, behind the horn contact. If you have a GM service manual, it shows how it is done.
Old May 22, 2010 | 09:10 PM
Jim Shea's Avatar
Jim Shea
You do not have to pull your steering column in order to replace the switch. You will have to pull your steering wheel and locking plate. You will have to pull your turn signal switch out from the column head in order to access the switch.
Here are full instructions:
http://jimshea.corvettefaq.com/wp-co...ev13my2010.pdf
http://jimshea.corvettefaq.com/wp-co...ev21mr2009.pdf
Jim
To 1980 Ignition Key buzzer switch
