Tach not set at Zero
Old May 25, 2010 | 12:51 AM
CarQz17's Avatar
CarQz17
Default Tach not set at Zero
I removed the tach from my 76 a while back. The needle sits on 1500 rpm now. Is there a reason for this? Is it broken, miscalibrated, or will it return to zero once power is fed to it?
Thanks.
Old May 25, 2010 | 12:56 AM
sabre1981's Avatar
sabre1981
mine doesn't sit at zero, its somewhere around 1000-1500 I believe, either way, mine does go down to zero once the key is turned to "on". I am guessing the tach is not put back in yet?
Old May 25, 2010 | 11:23 AM
CarQz17's Avatar
CarQz17
No, I haven't reinstalled it. Thanks for the heads up though. Does anyone know the reason behind it not sitting at zero?
Old May 25, 2010 | 12:42 PM
Artsvette73's Avatar
Artsvette73
The tach is reading the last rpm before the ignition is shut off. When you power up again before you crank it will return to ZERO
To Tach not set at Zero
