8 Track Playback Speed
Jun 8, 2010 | 09:32 PM
Posting for a neighbor with a recently acquired '78 with factory 8 track player.
How do you adjust the playback speed? His plays too fast to the point you can't recognize the singer.
Thanks in advance.
cc
Jun 8, 2010 | 09:35 PM
i would change the tape first to see if its the deck or the tape .
Jun 8, 2010 | 09:53 PM
Quote:
Originally Posted by
terry82
It does it with all of the tapes.
Jun 8, 2010 | 10:29 PM
Look inside and check for tape wrapped around the capstan.
This makes the capstan diameter larger which pulls the tape faster.
Jun 8, 2010 | 10:45 PM
Thanks Fred, I'll pass that tip along.
cc
Jun 9, 2010 | 10:10 AM
Cruise-In II Veteran
Check the owner's manual. He might be able to slow it down with the unit in the dash.
Jun 9, 2010 | 11:04 AM
Thanks Mike, I'll ask him if it came with an owner's manual and if so suggest he check it.
Jun 9, 2010 | 05:27 PM
............Check the FF !
Jun 11, 2010 | 07:07 AM
Hammerhead Fred ...Is right on target, check the capstan. There is a small screw on some models (not on all)that allow for speed compensation but that seldom is the problem.
Jun 11, 2010 | 07:52 AM
Hope this helps.
Jun 11, 2010 | 08:11 PM
I had the same problem with my 77. I used the above diagram from Binnie. Mine had to be adjusted with a small allen wrench to the left of the large drive wheel. Look closely for the adjustment screw,hard to see.You will probably have to remove the 8 track to adjust
Jun 11, 2010 | 10:33 PM
Looks like we are going to make use of the diagram and info about the motor speed adjustment. No tape found wrapped around the capstan.
Thanks guys.
cc
