74 engine bay decals ??
Old Jun 9, 2010 | 04:42 PM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
Default 74 engine bay decals ??
Other than the "Keep Yo GM all GM" on the breather and the engine spec decal on the firewall......does a 74 LS4 have any other decals under the hood or on the covers?
Thanks for any help here.....
Old Jun 9, 2010 | 05:06 PM
Alan 71's Avatar
Alan 71
Hi ffb,
How about the 3 letter broadcast code that was on a sticker on the right-side valve cover?
It's a bit tricky to find a reproduction. ( Hint.. you may have to make one yourself if you really want one).
Regards,
Alan
Her's one from my 71.
Old Jun 9, 2010 | 05:18 PM
Roscoe's Avatar
Roscoe
I think on the crankcase vent tube there is a tag with #'s. It just depends how far do you want to go. Pick up a NCRS Tech Manual......... $$ = Points
Old Jun 9, 2010 | 05:38 PM
gbvette62's Avatar
gbvette62
There should be an orange "Warning" label on the overflow tank. There was a tag on the master cylinder bail with either "TG" (power brakes) or "YA" (standard brakes) in red letters. The wiper motor had a label on it with the part number and a date. Also, if you have air conditioning there was a "Frigidaire" label on the compressor and a "Harrison" label on the evaporator/heater box.
All of the above are reproduced, the broadcast code that Alan referrenced, as he said is not.
Old Jun 9, 2010 | 08:04 PM
Roscoe's Avatar
Roscoe
Zip use to sell the valve cover code's.
Buy the CJ & the LL code cut the LL in half then you have CJL & attach
Originally Posted by Alan 71
Hi ffb,
Regards,
Alan
Old Jun 10, 2010 | 10:37 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Here ya go. Great photo reference here. Lots of underhood pics. Text has a listing of stickers and decals.
If memory serves, there should be a Tonawanda, the #1 Team decal on the RH valve cover.
Old Jun 10, 2010 | 10:44 AM
Paul L's Avatar
Paul L
Also the emissions decal behind the master cylinder.
Old Jun 10, 2010 | 12:55 PM
gbvette62's Avatar
gbvette62
No "Tonawanda #1" Team label on 74s, 67-70 BB only.
Paul, I think he has the emission label, as he said he has the "engine spec decal".
To 74 engine bay decals ??
