differential cross member fit??
Old Jun 12, 2010 | 05:03 PM
andycw's Avatar
andycw
Default differential cross member fit??
I am in the process of reinstalling Fletcher's 72's rear diifferential, springs, shocks, trailing arm etc. Basically, I had some popping in the rear end and decided to tackle the issue. We replaced the u-joints, and had the trailing arms rebulit by van steel. I powdercoated all the small parts that I could. I had a local rebuild the differential and he determined that the passenger side yoke was not within tolerance. We also found a small crack in the differential cover. So, I ordered all the parts I needed from Willcox. I bolted the diff cover on, filled it with GM additive and diff oil. My next step was to bolt the new diff cover to the rear cross member. However the bolt pattern would not line up. The rear of the cover keeps the cross member pushed back too far which will not allow the holes to align. I checked the cross member with the old cover and the fit was perfect. has anyone ever had this problem? Also, can I save the oil somehow and put it back when I get a replacement?
I sent Willcox and email and Im sure they will take care of it. I just hate that I've got to wait another week or two to finish.
Thanks,
andy
Old Jun 12, 2010 | 05:24 PM
...Roger...'s Avatar
...Roger...
I've had to grind the corner along the whole edge before on some covers.
Old Jun 12, 2010 | 08:06 PM
andycw's Avatar
andycw
Default how much
Roger,
How much grinding did you have to do? i really don't want to have to wait for another but I also dont want to ruin it.
andy
Old Jun 12, 2010 | 10:18 PM
...Roger...
Not much , about a minutes worth with a 4" wheel. I just had to remove the corner so the crossmember would move forward. The edge on the crossmember is rounded so once I took the corner off the housing it moved forward about 1/4" and the holes lined up.
Old Jun 12, 2010 | 11:05 PM
andycw's Avatar
andycw
Default grinding
Thanks Roger. I'll give that a try tomorrow. No turning back once I take that step lol
Old Jun 12, 2010 | 11:12 PM
...Roger...
I would look real close and see how much you have to grind to make it work , Ernie might give you the go ahead to see if it will work.
How far off are the holes ?
Old Jun 12, 2010 | 11:40 PM
andycw's Avatar
andycw
Default off
I can get all four bolts in with the cross member angled slightly up on the cover side. Once there in, it leaves about a 1/8th gap at the bottom. So I guess about 1/8th. I hate to waste tomorrow waiting to se if he'd give me the go ahead. How thick is the wall/corner of the cover. Do I have 1/8th that I can grind off?
andy
Old Jun 12, 2010 | 11:53 PM
...Roger...
Mine didnt hit the back wall of the cover. On mine the flat the holes are drilled in and the cross member sets on was not wide enough.
Would it be easier to remove some of the lip on the cross member ?
I always put the crossmember back on the same way it came off,could you have flipped it and one side has more metal ?
Old Jun 13, 2010 | 12:10 AM
andycw's Avatar
andycw
Default fit
Its not hitting the lip on the crossmember. Its hitting the side below it. I tried it both ways and the fit was the same. Ill look at it tomorrow and see if the corner is the problem all the way across.
Thanks Roger.
andy
To differential cross member fit??
