cross member install help
Old Jun 13, 2010 | 01:26 PM
andycw's Avatar
andycw
Default cross member install help - pics
hey all,
I'm attempting to reinstall my cross member with rear differential attached. I've cleaned the round metal frame pieces that slide into the cross member in order to make install easier. The problem is the cross member doesn't seem to pull all the way up when tightening the bolt. I've tried putting the floor jack under and jacking but that just lifts the car. any ideas on how to snug ut up tight?
thanks,
andy
Old Jun 13, 2010 | 02:05 PM
andycw's Avatar
andycw
Default pics
here are pics of what im talking about.
Old Jun 13, 2010 | 03:04 PM
andycw's Avatar
andycw
Default moving on
I pulled the bolt out and it is seated completely snug. I guess this gap is normal.
andy
Old Jun 13, 2010 | 03:31 PM
...Roger...'s Avatar
...Roger...
That doesn't look bad,if the threads the bolt is going into is just inside the hole then your done. I went back and looked at the link I sent you and it appears to be too close but it could be the angle of the pic.
Old Jun 13, 2010 | 05:38 PM
Gordonm's Avatar
Gordonm
Yes the gap is normal. It does not sit flush like you think it should. You are fine right there.
Old Jun 13, 2010 | 05:50 PM
camber's Avatar
camber
from what I can see from the pictures--your good to go---camber
Old Jun 13, 2010 | 06:23 PM
TimAT's Avatar
TimAT
Looks right to me too. After you drive it you could check the bolt torque again to confirm.
To cross member install help
