Fuel Cell
Lower CG.
Was thinking the same thing also.....
I also really enjoyed fabricating the bumper bar, brackets, and cage for the cell!
The instructions will tell you to mount the cell in a cage made of 1" box tube. I really enjoyed welding and fabricating the cage, brackets, and bumper bar. Again, this may not work for you since you have a 77 body...
The SP126B is more of a square shape, and is taller than most other cells. I ordered it with a 45 degree offset filler neck and turned the neck 30degrees. The filler neck is positioned perfectly in the stock filler door opening!
The only complaint I have about this fuel cell (other than the cost) is that it takes a long time to fill. I have to pump the gas very slowly as the neck is very short and the fuel splatters out and shuts off the pump.
In summary, I wouldn't recommend this mod unless you are comfortable with some fabrication and welding. And it will cost probably around $1000 more than a reproduction tank. If you'd like, I can send pics of my installation. PM me if you want them. I didn't renew my .Mac subscription, so my website no longer works.
http://www.atlinc.com/pdfs/Racing/20...og-web%204.pdf
One thing about these....they hang down pretty good,and wouldn't want that hanging below the back of my car.These cars are plastic,and not even a hard collison would scare me with it hanging low.
I was going to use it in my 68 with the new motor,but .....it's collecting dust too!
If you are interested,then pm me.Ask about the non-bladder tank to redvetracer,or the SkunkWorks.They both are real road racers,and knopw their way around all these mods.
Kevin
