garage floor
Old Jun 25, 2010 | 01:51 AM
1955pirate's Avatar
1955pirate
Default garage floor
Gutting my garage.....tearing it down to the studs and putting in new sheetrock, new shelving, new lighting, etc. So, what kind of floor have you put down over the concrete that is cool and durable.
Corvette (Thought I better have that word in there so the post fits)
Old Jun 25, 2010 | 03:16 AM
Frogday's Avatar
Frogday
I used Epoxy-Coat base coat with a clear coat. It has held up fine with two lifts on it.
Old Jun 25, 2010 | 08:15 AM
7T1vette's Avatar
7T1vette
I am in process of putting down the Quikrete epoxy floor coating on mine. About one-half of the floor is done so far. I like the look and it appears to be a sturdy epoxy coating, but [obviously] have not had time to test it under conditions of use, yet. I did not put the clear coating over mine, as I was concerned about it being too slippery when it was a little damp (from mopping, rain drippings off car, etc.). But, that floor with the clear coat certainly looks nice!
I think coatings with the speckled chips in them help to 'hide' any dirt; the chips also reduce the slickness of the coated surface. I also chose a very light color (cream/ivory) so that I could get the most reflected light possible.
Old Jun 25, 2010 | 08:46 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
Peel and stick 12 X 12 linoleum squares, alternating black and white. It was cheap, looks great and has held up extremely well over the last 8 years.
Old Jun 25, 2010 | 09:34 AM
Rickman's Avatar
Rickman
Capevettes,
What was the prep for the linoleum squares?
Thank you in advance,
Rickman
Old Jun 25, 2010 | 11:10 AM
75+78 Corvettes's Avatar
75+78 Corvettes
QuickCrete epoxy paint. Has held up for almost 5 years now with lots of oil, antifreeze and brake fluid spills and has been impervious to all. when it does need to be cleaned, hose it down with some simplegreen and then blow the water out with the leaf blower and it's good as new
Old Jun 25, 2010 | 11:19 AM
crossed's Avatar
crossed
Nice, i might try that, my garage has a wooden floor
Old Jun 25, 2010 | 12:14 PM
7T1vette's Avatar
7T1vette
Old machine shops and printing shops used to have wooden floors. They were 'stacked' pieces of 4x4's set in on-end [grain was up/down]. They soaked up ink, oil, grease...just about anything. The only thing you had to do was broom it off every now and then. Of course, you had to wear the "shop shoes" when you worked...and took them off when you left. Otherwise, you would leave black footprints wherever you walked. I'm pretty sure that's not the kind of wood floor you have, but that brought back a very old memory.
Old Jun 25, 2010 | 12:37 PM
capevettes's Avatar
capevettes
CF Community Team
2016 C2 of Year
Originally Posted by Rickman
Capevettes,
Rickman
Nothing special. I just made sure that the concrete floor was clean and dry. I vacuumed it completely before I started laying it down. Not a single one has come up in 8 years.
Old Jun 25, 2010 | 02:53 PM
SIXFOOTER's Avatar
SIXFOOTER
I used a pressure washer and then a leaf blower on mine for prep
Old Jun 25, 2010 | 03:09 PM
chiefbob's Avatar
chiefbob
St. Jude Donor '10
I was going to use Rustoleum epoxy floor paint for mine, as my old basement turned out great with that.
But after seeing your photo, I may go the route of cheap floor tiles. Maybe in Red and White!
Thanks for posting the pic.
Bob
Old Jun 25, 2010 | 03:17 PM
camber's Avatar
camber
floor tiles--turning the car wheels or floor jacks does it stand up to regular garage use???????looks good but does it take some abuse--camber
Old Jun 25, 2010 | 03:43 PM
builder's Avatar
builder
Aren't you supposed to use muratic acid to clean the floor first?
Old Jun 25, 2010 | 08:03 PM
chiefbob's Avatar
chiefbob
St. Jude Donor '10
I've seen that reference, but also TSP (trisodium phosphate). I used TSP, scrubbed it with a wide push broom, then diluted it with water and mopped it up (couldn't use the leaf blower as it was my basement that I painted).
Bob
Old Jun 26, 2010 | 12:50 AM
Flying Low's Avatar
Flying Low
Last one of those I saw was in and old gage shop in Tennessee, I think it was Southern Gage Over 20 years ago.
Old Jun 26, 2010 | 01:23 AM
PUNISHER VETTE's Avatar
PUNISHER VETTE
I should probably think about doing something to my garage floor as well.
I'm only 23 but working on the car has made my back start to hurt. Most likely from sitting and laying on a cold cement slab.
Maybe those rubber tiles that piece together wouldn't be bad?
has slots in it so might be hard for spills, jacks, screws...so most likely a poor choice.
better non- slotted tile....
http://www.mygaragestore.com/images/...eeflow_lrg.jpg
Old Jun 26, 2010 | 01:44 AM
Skip Burney's Avatar
Skip Burney
Have you ever tried to roll a floor jack or creeper on those things AINT GONNA WORK
To garage floor
Old Jun 26, 2010 | 09:46 AM
SIXFOOTER's Avatar
SIXFOOTER
Yea one gets torn up now and then, but the nice thing is they are cheap and you can replace them easily, I think they are 63 cents or something.
you only need the acid or TSP if the floor is really slick, or oily. all mine needed was to get the cheap paint off and dust washed off. Pressure washer and leaf blower took care of all that in under an hour
Old Jun 26, 2010 | 10:22 PM
crossed's Avatar
crossed
hehe, no, it would be a little better if it was though. Years ago the previous owners of my house took apart a small house out in town for a guy and brought it piece by piece to this property and reassembled it as a workshop. It was just a hardwood floor. I put a garage door in and strengthened the floor under where the car can sit and now its just a scabbed together wooden floor. Its a little small to be a garage, to work in, but its perfect storage for a car.
Old Jun 27, 2010 | 09:39 AM
vette54728702's Avatar
vette54728702
There are lots of ideas, but the best one I have ever seen pictures of was a hard wood floor... of course he didn't use his garage as a shop either (that's always something to consider). Good luck
