L86 vs LT1
Old Jul 10, 2010 | 10:07 AM
AvRog's Avatar
AvRog
Originally Posted by Ed Campbell
I have had mine to 7000 rpm with no ill effects. I think shifting at 6200 is probably about right unless you can run out the finish with out shifting and them go for the overrive. Sure makes beautiful noise at 7000 though. Ed
So where do the stock L68 guys shift?
Old Jul 11, 2010 | 10:32 AM
AvRog's Avatar
AvRog
Anyone know the ideal shift points for the L68?
Old Jul 11, 2010 | 04:47 PM
LS WON's Avatar
LS WON
I would just get in automatic if they came that way for straight line performance.
Old Jul 12, 2010 | 07:17 AM
bashcraft's Avatar
bashcraft
Originally Posted by Solid LT1
Were you the IDIOT who cut the LT-1 hood on my wife's 70 roadster and exploded the clutch through the flooboards before putting on a poorly fitting scattershield? (Just kidding!)
First I thought, man what a bad carb fire this Vette must have went through, then after further study, I realized HEY! some EFFING idiot cut this hood to put a tunnel ram on the motor way back in the day (another reason why I know the Vette is a true 70 LT-1)
No, that wasn't me. I still have the car that I cut the hole in the hood for the tunnel ram ( the same one in my avatar). But it was an aftermarket hood. Oh, and I did explode a clutch in the same car right before I installed a blowproof bellhousing. I still have the LT-1 engine sitting in my garage.
Old Jul 13, 2010 | 02:15 PM
AvRog's Avatar
AvRog
I have the original THM400, if I let it shift itself it will do so by 3000rpm
Old Jul 13, 2010 | 02:51 PM
LS WON's Avatar
LS WON
Is this good or bad cause the tranny knows when to shift without blowing itself up.
Old Jul 14, 2010 | 05:41 AM
AvRog's Avatar
AvRog
This is good if it were a diesel truck?
Old Jul 14, 2010 | 10:57 PM
RacinJason68's Avatar
RacinJason68
sounds like your th400 needs a shift kit. Or leave it in 1st gear and hold it to the floor. It should dummy shift, and chirp the tires when going into second.
I have had a few friends that didnt realise the TH400 would do this, they went out and tried it on dirt roads... dumb move. Highway for the test, the motor will wrap and then bang 2nd. after it hits second, you can manually shift to drive for the finish.
Old Jul 15, 2010 | 08:11 AM
AvRog's Avatar
AvRog
When I want the car to go I manually shift and it does put down rubber going into 2nd and 3rd. The reason I started the thread is because I am having trouble getting the car to make good power past 4000 rpm.
Old Jul 19, 2010 | 07:36 AM
AvRog's Avatar
AvRog
What is dummy shift?
Rog
Old Jul 19, 2010 | 11:00 PM
RacinJason68
I call it a dummy shift. The tranny will force a shift at the top of 1st gear.
Old Jul 19, 2010 | 11:07 PM
RacinJason68
found on another forum....
The TH400 will upshift (with the shifter in 1st) to second around 5500 rpm, it is the governor that causes it.
It will happen. I have been in a few vehicles that have done it. hold it wide open and let it shift. We put one behind a 305 and it would hammer the 12bolt and chirp the tires all the time in that Jimmy.
Old Jul 20, 2010 | 08:16 AM
  #33
AvRog's Avatar
AvRog
Thats good to know
Thanks, Rog.
Old Jul 20, 2010 | 11:37 AM
  #34
Les's Avatar
Les
Mine stays in first until I move the shifter to second....up to 6500 RPMs and beyond. I wouldn't depend on the trans shifting for you unless you're willing to risk grenading your motor.
Old Jul 20, 2010 | 11:05 PM
  #35
RacinJason68
someone has prob been into your tranny or the vac. module has been played with. I cant say it works for all trannys but the ones I have been in we held it to the floor and waited for the shift.
Old Jul 21, 2010 | 08:02 AM
  #36
AvRog's Avatar
AvRog
If I put my tranny in 'Drive' it short shifts at about 2000 ish rpm. I assume this is Not normal?
