Bolt size needed for spark plug shields
Old Jun 27, 2010 | 02:37 PM
Rudy's Stingray's Avatar
Rudy's Stingray
Default Bolt size needed for spark plug shields
Greetings!
I need the bolt and thread size needed to attach the spark plug shields
to the block. I see the female threads in the block but I didn't want to
guess and use one that looked correct only to strip out the threads.
Thanks.
Rudy
Old Jun 27, 2010 | 02:39 PM
Skip Burney's Avatar
Skip Burney
Originally Posted by Rudy's Stingray
Greetings!
Thanks.
Rudy
You won`t strip any threads is you use your fingers to run it in instead of a wrench I think they are 1/4 20 but I wouldn`t bet my dog on it
Old Jun 27, 2010 | 05:51 PM
Duke94's Avatar
Duke94
1/4-20 Thread. Make sure you use the correct length as the hole is not very deep so the bolts are rather short. I think 1/2" long.
Gary
Old Jun 27, 2010 | 05:59 PM
Chuck72's Avatar
Chuck72
Gary
Great advice, cuz if you use a 1/4-20 (correct), which is too long, and you snug it too much, and it breaks off in the hole, now you have got yourself a major problem!
Regards,
Chuck
Old Jun 28, 2010 | 03:46 PM
Rudy's Stingray
Gents,
Thanks to all who replied.
This does appear to be the correct side.
I bought (16) #8 1/4 - 20 by 1/2" today and plan on painting them this
week with high heat paint and put on the car over the weekend.
Have a good week.
Rudy
Old Jun 28, 2010 | 04:20 PM
7T1vette's Avatar
7T1vette
If those are Grade 3 (soft steel) bolts, they only get torqued to about 8 ft-lbs.
To Bolt size needed for spark plug shields
