Dip Stick......
Old Jun 27, 2010 | 07:31 PM
Richard Cooper's Avatar
Richard Cooper
Default Dip Stick......
I got my new crate motor installed. I also did away with the computer on my 81. I also got different exhaust manifolds installed. I am just about done with everything and go to install my new dip stick, only it will not fit between the block and exhaust manifold. The new manifolds are very close to the block. I can squeeze the tube down between the manifold and block but its at the wrong angle to get in the hole for the tube. Has anyone had this problem and if so what did you do? Thanks, so close, yet so far.
