1978 Headlight Change Procedure
Old Jul 2, 2010 | 02:43 PM
chiefbob's Avatar
chiefbob
St. Jude Donor '10
Default 1978 Headlight Change Procedure
My high/low beam light is out on the low but the high works. Is the remove/replace process as simple as removing the front cover panel and then removing the light?
Or is there some hidden gremlin that I should beware of?
Are the lights available at most auto parts stores or special order for Covettes?
Also wondered about replacing them with Halogen lights as advertised in Ecklers?
So many questions for what should be a simple job.
BTW, Happy Fourth of July!
Old Jul 2, 2010 | 04:17 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
It's pretty straightforward. Remove bezel; remove retaining ring and spring; unplug harness from rear of the lamp.
Might as well clean the harness plug while you're there.
Gremlins involve old and possibly siezed screws. Go slowly.
Old Jul 2, 2010 | 04:44 PM
markdtn's Avatar
markdtn
Regular old round light available at any parts store, wal-mart, etc.
Old Jul 2, 2010 | 05:41 PM
Swift_C3's Avatar
Swift_C3
Retaining spring? ..... maybe the 75 didn't have one, cuz all I had was a metal ring holding the light in, and springs holding the buckets(?) in the correct lighting position.
Old Jul 2, 2010 | 05:43 PM
72LS1Vette's Avatar
72LS1Vette
You may find some rust on the buckets when you get the bulbs out. It never hurts to spen a few minutes spraying a couple coats of paint on to help them last another 40 years.
Rick B.
Old Jul 3, 2010 | 07:23 AM
chiefbob's Avatar
chiefbob
St. Jude Donor '10
Thanks, guys, for the tips and pics.
Bob
Old Jul 3, 2010 | 07:58 AM
...Roger...'s Avatar
...Roger...
In some years the spring hooked through the silver ring but I think in later years the spring just hooked the bucket.
Maybe Chiefbob can confirm.
Old Jul 13, 2010 | 09:58 AM
chiefbob's Avatar
chiefbob
St. Jude Donor '10
I changed the headlights this morning and can confirm that the springs are attached only to the buckets. Here's a pic (damn, the dirt and dust really show up on closeups!):
Old Jul 13, 2010 | 12:47 PM
Young69Owner's Avatar
Young69Owner
My screws were all kinds of rusted. I had to saw a niche into them and then take a flathead! I converted to H1 bulbs and now it is even harder!
Old Jul 15, 2010 | 10:24 AM
kingkohlmn's Avatar
kingkohlmn
Veteran: Marine Corps
Default Try this
http://forums.corvetteforum.com/c3-g...or-anyone.html
Thanks Bill
To 1978 Headlight Change Procedure
