Compression Test: Warm engine first?
Old Jul 8, 2010 | 06:13 AM
briaineo's Avatar
briaineo
Default Compression Test: Warm engine first?
Was reading an operation manual for a compression tester that harbour freight sell, its says to warm the engine to normal operating temp before removing the plugs! This necessary? Would like to avoid removing the plugs beside roasting headers. Havnt heard this before, is the manual correct? Must you put your foot on the gas pedal too?
Connect the Compression Tester to the first cylinder of the engine. With the fuel
pedal depressed all the way down, crank the engine for at least eight revolutions.
Old Jul 8, 2010 | 09:58 AM
Poppa Bud's Avatar
Poppa Bud
Cruise-In IX Veteran
St. Jude Donor '08 thru '13
Yep, that's the way to do it.
If you're concerned about having a bad valve or broken rings on one or two cylinders you could do a cold test. Compare the numbers on all cylinders and see if any are out of range.
The warm test is better if you're concerned about normal wear.
Old Jul 8, 2010 | 01:13 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
You've piqued my interest. What would be the purpose of holding the accelerator pedal down?
Old Jul 8, 2010 | 01:22 PM
briaineo's Avatar
briaineo
Think flooding the engine is the only possible purpose!
Old Jul 8, 2010 | 02:01 PM
929nitro's Avatar
929nitro
Never heard of that one. I used to do it alone with a remote starter button, no throttle used.
Old Jul 8, 2010 | 02:49 PM
Easy Mike's Avatar
Easy Mike
Ditto. Coil wire pulled out of the cap. The car was not going to start.
Old Jul 8, 2010 | 03:54 PM
bashcraft's Avatar
bashcraft
The purpose of a compression check is to compare the numbers between all the cylinders. Any that deviates from the rest indicates a problem. The actual number itself is rather meaningless since different cam specs and profiles will drastically change the readings. So, warmup is not necessary, nor is holding the throttle open. Just check all cylinders under the same conditions and it'll give you the information you're looking for.
Old Jul 8, 2010 | 06:05 PM
10caipirinhas's Avatar
10caipirinhas
Always done them cold for obvious reasons, and with a remote starter and the coil unplugged as well. Compare the first and second pulse of the needle on the gauge when you are checking each cylinder.
To Compression Test: Warm engine first?
