custom door panels
Old Jul 13, 2010 | 07:39 PM
veronicas dad's Avatar
veronicas dad
Default custom door panels
hi all,
i have a '76 and very little money to put into it. i was wondering if any of you guys have custom door panels that you did yourself with low cost materials. i've seen the green tweed pic and that looks good and definatly an option for me. but what else is out there? i'm looking for simple and elegant designs but anything will help me decide what to do.
Old Jul 14, 2010 | 02:49 AM
7T1vette's Avatar
7T1vette
It really depends on how much damage your existing panels have. If they are just cracked in some areas without any big tears or missing areas, you might be able to patch them with some polyester body putty. Once the surface has been repaired, you can clean the panel and give it a new coat of vinyl dye [SEM "Color Coat" is the best, as far as I'm concerned]. If the patch was done well, your panel will look nearly as good as new. Cost: $5 for tube of body putty; $15 for a pint of SEM dye and $5 for a PreVal gas/bottle sprayer. Would that work for you?
Old Jul 14, 2010 | 02:50 PM
veronicas dad
that would definitely work for me. thanks for the advice. how hard is it to put the patch in, do you just fill it in and sand it down?
Old Jul 14, 2010 | 04:13 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
How bad are they? You could be pleasantly surprised at how much better they can look after a thorough cleaning.
Original panels are ABS plastic formed over a paper substrate. The grained look is molded into the ABS.
To custom door panels
