Another Heat Insulation Consideration - AC Plenum
Old Jul 15, 2010 | 06:17 PM
68/70Vette's Avatar
68/70Vette
Default Another Heat Insulation Consideration - AC Plenum
I removed what I would call the AC Plenum. This is a two piece "box." The left side of the plenum contains the fan and the right side contains the evaporator.
As far as heat loading this arrangement is kinda of a jaw dropper. The evaporator plenum side is only a scant couple of inches (?) from the exhaust manifold. So for heat input you have an engine exhaust manifold that's perhaps 1400 degrees F (?) and couple of inches of engine air, about 1/8 inch of evaporator plenum wall thickness and then post evaporator chilled air at about 35 degrees F. That the wall of the peunum becomes extremely hot became obvious when I removed the entire AC Plenum. Taking it out, I saw some holes in the plenum wall facing the engine...obviously something to be plugged up...I thought perhaps someone during a previous engine install had banged the engine into the plastic wall and cracked it. The engine is a BB and a tight fit. In the light of day, I could see that the holes were caused by heat damage. The plenum material is naturally a very dark grey. The side facing the engine was now brown. It had been scorched and became very brittle due to engine manifold heat. The holes occurred to heat deterioration.
When I replace the AC plenum (I'm going to try to find an unscorched piece), I was thinking about putting insulation on the exterior wall to protect it from engine heat and also place a thin layer of fiberglass insulation on the inside of the plenum to prevent the engine heat from causing a parasitic heat load onto the chilled post evaporator air.
The aftermarket add-on AC's that place the evaporator inside the car really create a big advantage for efficiency by getting the evaporator out of the engine compartment. Wonder why GM didn't try to do this. The stock system seems a brut force way.
Old Jul 16, 2010 | 09:06 AM
ED79's Avatar
ED79
Ed
Old Jul 16, 2010 | 01:04 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by 68/70Vette
...Wonder why GM didn't try to do this...
Ask them. There may a retiree somewhere who knows the answer.
Old Jul 16, 2010 | 05:36 PM
CCrane65's Avatar
CCrane65
By comparison, all of the after market units of the day were under dash units so there really wasn't anything better than the factory systems.
cc
PS, at least they weren't big cylinders mounted to the roof/window frame.
Old Jul 16, 2010 | 10:50 PM
theother_bob's Avatar
theother_bob
good information! thanks 68/70!
I think I'll insulate mine before I start driving her...
A/C is important in Texas!
Old Jul 16, 2010 | 11:08 PM
mds3013's Avatar
mds3013
We use a 1/2in. duct liner glued into sheet metal duct work in our shop. It is very similar to the hood liner used on my '77. You should be able to get small quantities at an A/C duct fab. shop. We throw away many small pieces every day. This is what you could use for the inside of the plenum. The outside may be a tougher fix as clearance to exhaust manifolds is an issue. Might be better to use a radiant barrier on the outside with the duct liner inside. Self adhesive aluminum tape would work but adhesive will fail due to heat eventually. mike...
Old Jul 17, 2010 | 12:10 PM
gr8t73's Avatar
gr8t73
I read an article not too long ago where it was recommended that the exterior of the A/C plenum should be coated with lizard skin.
Old Jul 17, 2010 | 02:58 PM
69 Convertible's Avatar
69 Convertible
any pictures?
To Another Heat Insulation Consideration - AC Plenum
