Torque Specs for headers and gaskets
Old Jul 16, 2010 | 06:43 PM
C3HOONIGAN's Avatar
C3HOONIGAN
Default Torque Specs for headers and gaskets
I put Hooker sides on my 74 last August, by the end of the month the gaskets had blown out. Does anyone know what the proper torque specs are? Also which gaskets are the best to use? the copper ones? Oh, and does anyone have any secrets as to getting a wrench on some of the hard to reach ones?
Old Jul 16, 2010 | 07:06 PM
Skip Burney's Avatar
Skip Burney
In the hard to reach places I use socket headed ones that I can get a big allen wrench on, I have used different kinds of gaskets but never torqued any of them just coat the bolts with anti sieze and run them down tight
Old Jul 17, 2010 | 07:34 AM
PowdercoatBill's Avatar
PowdercoatBill
You'll have to run the car for a bit and retighten the bolts. You'll do this several times before they'll stay put.
Beleive it or not I've had pretty good luck with the paper gaskets. Soak em in water for about 15 minuts before you install em. When they're wet and mushy the header sinks into em real good. Give it an hour or so before you fire it. Again check and retighten the bolts.
Old Jul 18, 2010 | 08:56 PM
C3HOONIGAN's Avatar
C3HOONIGAN
Any particular brand of paper gaskets?
Old Jul 18, 2010 | 09:51 PM
PowdercoatBill
Mr Gasket makes some. What kind of power do you think your motor makes? Is it stock or modified?
Old Jul 19, 2010 | 07:17 PM
C3HOONIGAN's Avatar
C3HOONIGAN
according to the PO it makes somewhere around 400hp, and I believe him.
To Torque Specs for headers and gaskets
