Shifter Plate Resto
Old Jul 18, 2010 | 11:35 AM
Dantana's Avatar
Dantana
Default Shifter Plate Resto
I'm doing some interior work while I have the dash out to put in my LED's and I thought I'd fix up my shifter plate. I'm having second thoughts about the gloss black paint I sprayed on there. Should this have been a flat black? I can redo today before I put everything back together. (I left the tape on the decal and lense)
Thanks,
Dan
Old Jul 18, 2010 | 11:47 AM
CA-Legal-Vette's Avatar
CA-Legal-Vette
I usually use dye on interior pieces and the gloss varies. Not sure how it compares as gloss is hard to gauge from your picture.
Did you paint over the chrome edges on purpose? If not, lots of folks do it the same way and then scrape the edges to exopse the chrome.
Old Jul 18, 2010 | 12:04 PM
Dantana's Avatar
Dantana
i painted the whole thing and I will use fine grit sand paper to expose the chrome edges.
Old Jul 18, 2010 | 02:29 PM
TimAT's Avatar
TimAT
I did mine with a semi-gloss
Old Jul 18, 2010 | 02:41 PM
wev's Avatar
wev
What colour is the upper peice to the console?
You want them to match, mine was satin black, now siliver/light grey
Old Jul 18, 2010 | 03:06 PM
Dantana's Avatar
Dantana
The gauge bezel is this same gloss color as this, I did it also. However, the reface kit I got for the heater/AC controls looks more flat.
Old Jul 18, 2010 | 03:21 PM
BBCorv70's Avatar
BBCorv70
I've used satin black in the past. Seems to be about the right amount of gloss.
Sprayed the whole panel, waited for the paint to dry for maybe a day, then used a razor blade to shave paint off the top edges where I wanted to expose chrome. Let it dry a bit more, then use fine steel wool to polish the chrome and remove any bits of paint left behind after shaving.
oldsarge's Avatar
oldsarge
I useds a semi gloss that was called trim mould black, it looks the same as original. You can get it at any automotive supply.
Old Jul 18, 2010 | 03:28 PM
Dantana's Avatar
Dantana
That looks fantastic oldsarge! It looks much more even than mine does. I'll go get some next chance I get.
How did you handle the chrome edges?
Old Jul 18, 2010 | 08:12 PM
DZRick's Avatar
DZRick
I re-did mine with John Deere blitz black and it matched the new heater controls perfectly.
Old Jul 18, 2010 | 08:21 PM
oldsarge's Avatar
oldsarge
I actually used painters tape and masked it all out, any edges that needed triming, I used a razor blade to shape things and carefully removed the excess tape. For the lettering, I just painted over, then right after painting, as soon as it is dry, I took the flat edge of the razor blade, and carefully scraped off the paint over the letters and such.
To Shifter Plate Resto
