68-72 big block hood
Old Jul 19, 2010 | 02:15 PM
rgarrett's Avatar
rgarrett
Default 68-72 big block hood
looking for opinions on best place to buy repro aftermarket big block hood for a 68? I dont see many originals selling?\
thanks
Rick
Old Jul 19, 2010 | 02:37 PM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
There is an original on EBay right now. Around $800.
Old Jul 19, 2010 | 05:01 PM
70BBvert's Avatar
70BBvert
Have a brand new repro available if you're interested.
Jim
Old Jul 20, 2010 | 01:21 PM
rgarrett's Avatar
rgarrett
how much are you asking for it?
I see a lot of the dealers are selling 2 different priced big block hoods? I assume one is better obviously, but anyone know the difference?
Old Jul 20, 2010 | 03:11 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by rgarrett
...I see a lot of the dealers are selling 2 different priced big block hoods?...anyone know the difference?...
There were two big block hoods: the LT-1/BB type hood and the L-88 hood.
Some vendors sell the L-88 type hood with and without the air box installed. Stock L-88 hoods had the air box.
Old Jul 20, 2010 | 03:13 PM
rgarrett's Avatar
rgarrett
im not referring to the L-88, only the LT-1/big block hoods, there seems to be 2 type of quality?
Old Jul 20, 2010 | 04:03 PM
gbvette62's Avatar
gbvette62
Yes. There is press molded or hand laid, fiberglass hoods. The press molded is smooth on the underside, this is the same type fiberglass as original GM glass. Hand laid is has a rough finish on the underside, like the inside of a boat hull. Sermershiem's probably make the best press molded hood, but it will cost you about $1,200. Forum Supporting Vendor ACI makes an excellent hand laid glass hood which sells for about half the cost of a press molded hood.
Press molded hoods are a far higher quality part, but if your not doing an NCRS car, the hand laid one may work just as well for your Corvette.
Old Jul 21, 2010 | 10:23 AM
70BBvert's Avatar
70BBvert
This one is a press molded hood, copied from a 68 hood. Bought it at Carlisle two years ago & then found an original available at a reasonable cost so I ended up using that one. I'll send you a PM
Jim
To 68-72 big block hood
