Early or Late
Old Jul 19, 2010 | 08:45 PM
Cobfree's Avatar
Cobfree
Default Early or Late
Can anyone tell me how to tell if I have an early 68 or late 68? Several parts are different.
Old Jul 19, 2010 | 08:52 PM
nutsy's Avatar
nutsy
68 vins started at 194378s400001. ended at s428566. the bigger the # the later the build.
Old Jul 19, 2010 | 08:57 PM
Cobfree's Avatar
Cobfree
Mine is a S425827 so it is in the middle
Old Jul 19, 2010 | 09:11 PM
1969RAY's Avatar
1969RAY
2025 C2 of the Year ('63 and '67) Finalist - Unmodified
C2 of Year Finalist (appearance mods) 2019
Mine is 16018 built and I think it is late, but most of it was in a box when I got it, so...
Old Jul 19, 2010 | 09:23 PM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
Any year vette is neither totally early or totally late. There was no set dividing line because GM engineering was on-going thru the production year. It all depends on which component you are referring to. Look in the '68 AIM and see if the component in question was revised (hint: the drawing has a title block in the lower right hand corner, with revision dates.) If the component has not been revised, then your car is neither early nor late with respect to that component. If it was revised, and if your car was built before that date, then your car is likely early with respect to that component. If your car was built after that date, then it is likely late with respect to that component. Have I confused you enough yet?
Old Jul 20, 2010 | 08:45 AM
Cobfree's Avatar
Cobfree
No, you have been helpful. I assume the AIM is the Assemble Instruction Manual? I have one at home and will look tonight. I need to replace the shift boot on my 4 speed. The last one I bought gave me some linkage problems and both of the options is Corvette Central look about the same thickness.
Old Jul 20, 2010 | 09:05 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
"Early" and "late" almost always refer to specific running changes made on the assembly line.
My Baby is #416660; April 20, 1968.
Old Jul 20, 2010 | 09:30 AM
avalonjohn's Avatar
avalonjohn
CF Community Team
Veteran: Marine Corps
St. Jude Donor '25
you have a pretty late car, off the top of my head either later June or July of 68? If your question is the shift boot, you have the later one with 2 bellows. Do you need one? I have a decent original if not the CC ones are fine. Good luck, john
Old Jul 20, 2010 | 09:33 AM
avalonjohn's Avatar
avalonjohn
CF Community Team
St. Jude Donor '25
just got out the NCRS "Corvette Birthday Book"...your car rolled off the assembly line July 18th 1968 (give or take a day)...production only lasted 4 more weeks after that so I'd say you have a pretty late car.
Old Jul 20, 2010 | 09:41 AM
Cobfree's Avatar
Cobfree
Great thanks for the help. I can now order the part.
Old Jul 20, 2010 | 10:41 AM
tomgallucci57's Avatar
tomgallucci57
mine is a s412447,,,plus, yesterday i was looking around in the rear compartment and i lowered the fiberboard type shelf,which im not sure what it is,and found in hand writing 2-15-68,,plus a few other numbers and possibly what looks like a signature.also on the front lip of the pass. side head its stamped v0208ihe, which ive found to mean v= flint mi. 02= feb. 08= 8th he= 300 hp
Old Jul 20, 2010 | 10:52 AM
avner's Avatar
avner
On the trim tag at the door what you have? G15?
On my trim tag it's G14 look like C14 so its one day before yours.
Avner
Old Jul 20, 2010 | 10:57 AM
tomgallucci57
looks like c 27
Old Jul 20, 2010 | 11:18 AM
avner's Avatar
avner
C27 / G27 = Feb 27 car assembled.
I think a lot of G stamp in 68 look like C.
We are not alone with this C / G stamp.
Avner
Old Jul 20, 2010 | 11:25 AM
gbvette62's Avatar
gbvette62
It's the storage tray for the removable rear window. You store the rear window in there when it's out, instead of just leaving it lay on the rear compartment floor. Many cars are missing them, so your pretty lucky it's still there.
Old Jul 20, 2010 | 02:54 PM
tomgallucci57
thats what i thought it was for,but i havnt tried fitting the window in yet.i see theres clips on it,,,thanks alot,,makes me feel good.only about an hour ago i was driving home,and the accelerator cable retaining clip must have fell out,lucky i had a pair of small vise grips to hold onto the little ball at the end of the cable to get it home..thanks again,tom
Old Jul 20, 2010 | 03:57 PM
Easy Mike's Avatar
Easy Mike
mine is a s412447,,,plus, yesterday i was looking around in the rear compartment and i lowered the fiberboard type shelf,which im not sure what it is...
Storage tray for the pop out rear window.
...also on the front lip of the pass. side head its stamped v0208ihe, which ive found to mean v= flint mi. 02= feb. 08= 8th he= 300 hp
That's the engine ID code; It should read V0208HE. HE identifies the 300hp base engine with manual transmission.
G27 would be February 27, 1968 the date your car passed the station on the assembly line where the trim tag was attached. Jives with your engine assembly date of February 8th since engines were assembled at Flint and shipped to St. Louis before the cars were assembled.
There is a second number on that pad. You should find your VIN derivitive stamped there.
To Early or Late
