I'm trying to figure out how the headlight override switch mounts under the dash... Took it off a couple of years ago and can't remember how it goes back... specifically the bracket that the switch mounts to.
There is a cover that mounts under the steering column, it has one screw that screws to the steering column. The other 2 screws appear to screw into the headlight override switch bracket but that doesn't seem to be correct (or strong enough for that matter!)... It's like those 2 screws don't have anything to screw in to...
Hi Tab,
The two screws go through the coluum trim piece, then through the over-ride switch bracket, and finally into 2 clips that are moulded into the bottom of the driver's-side dash pad. The 2 screws do firm everything up.
As Mike said, the info is in the AIM.
Regards,
Alan
Hi Tab,
Regards,
Alan
Thanks Alan, I don't have the AIM but it appears that those 2 clips that are moulded into the bottom of the dash pad are long gone. I guess I will be careful when pulling on that switch. I really never use that anyway.........
