Last layer of primer
Old Jul 23, 2010 | 07:27 PM
79vetter's Avatar
79vetter
Default Last layer of primer
I'm in the process of stripping the hood and am down to the layer of Epoxy Primer that was on the car. What is the best way to bring this down to the bare glass? What sand grit would be appropriate?
thanks
Old Jul 23, 2010 | 07:34 PM
nutsy's Avatar
nutsy
im no painter but i dont know if you should go down to the bayer glass.
Old Jul 23, 2010 | 07:43 PM
zwede's Avatar
zwede
Are you sure it's epoxy primer? Factory used lacquer primer which is removed with lacquer thinner, scuffpads and (lots) of elbow grease.
Nutsy: You always want to get down to the 'glass. Don't want to put a modern urethane paint on top of 30-40 year old lacquer.
Old Jul 23, 2010 | 08:52 PM
79vetter's Avatar
79vetter
yes - its fresh epoxy primer - need to start over ..
Old Jul 23, 2010 | 09:20 PM
zwede's Avatar
zwede
Sorry to hear that.
Not sure what gets epoxy primer off. Have you tried aircraft remover?
Old Jul 23, 2010 | 11:12 PM
Georgia1974's Avatar
Georgia1974
Get the primer off
80 grit on a sanding block, I like the longer boards 16" until you get the primer off, use some finishing putty, then go 180 grit after that 220 grit. It will finish like glass.
Old Jul 24, 2010 | 08:55 AM
jnb5101's Avatar
jnb5101
why do you think all the epoxy has to be removed? if it didn't come-out smooth, just sand the rough spots and re-spray (of course sand the entire hood for better adhesion). use the coats of epoxy as blocking coats. and if the glass needs to be repaired, the epoxy resin will bond to the epoxy primer.
Old Jul 24, 2010 | 10:01 AM
79vetter's Avatar
79vetter
My painter wants to start over due to a bubble that keeps popping up..We want to get down to the glass and give it a good clean/prep in case there is some cantaminates.
Anyone have a good method to remove the layer of SPI Epoxy primer?
Old Jul 24, 2010 | 10:16 AM
turbojet's Avatar
turbojet
Does your car have AC
Old Jul 24, 2010 | 10:21 AM
79vetter's Avatar
79vetter
I know where you are going with this but no, its at the very tip of the hood - don't think its compressor oil - thanks
Old Jul 24, 2010 | 11:06 AM
jnb5101's Avatar
jnb5101
start with 80 grit, when you start to see glass, go to 150 or 180. don't worry about going too deep, a thin layer of filler will rebuild the contours. if there's oil in the glass (someone went crazy with pb blaster ?) you'll have to remove a much deeper layer of material and then build it back to the proper contour. if you try to use solvents to clean the oil, all you'll succeed in doing is spreading the oil deeper into the glass.
To Last layer of primer
