Locked Door
Old Aug 1, 2010 | 08:21 PM
Burnt71's Avatar
Burnt71
Default Locked Door
OK I give up. I have a passenger door that will not open. I think the lock is stuck. Manual lock works back and forth but I think it's not unlocking. How can I open this door without destroying anything ?
Old Aug 1, 2010 | 08:40 PM
68-427Rich's Avatar
68-427Rich
Default Locked door
Nothing works from the inside or outside?
Old Aug 1, 2010 | 08:44 PM
Burnt71's Avatar
Burnt71
Nothing
Old Aug 1, 2010 | 10:08 PM
Lemans Blue 69's Avatar
Lemans Blue 69
Seen that problem many times on GM vehicles. When you either press down on the outside handle or pull the inside door release, an actuator is pushed down which is not mechanicallly connected to either release. It has its own spring to restore it to its proper position. Many times that spring will either break or the pivot the lever is mounted on will rust to the point where the spring can't return it to its home position. The give away to that problem is you may think the lock cylinder or inside turn **** is fully restoring the actuator but it is just shy of fully restoring it to allow opening of the door.
If that is your situation, you manually have to use a car opening tool to lift the actuator up. Then the key or inside turn will unlock the door. Like I said, seen it many times on GM vehicles. Sometime a spray of WD40 sprayed blindly down the door panel will free the actuator with some vibration and allow you to open the door.
Then pull the panal and make the fix. Thats my first suggestion.
Old Aug 1, 2010 | 10:25 PM
dburgjohn's Avatar
dburgjohn
mine did that. had to pull pannel with door shut. reached in and lifted latch rod and it opened. Decided it was a good time to clean and oil latch
Old Aug 2, 2010 | 12:04 AM
68/70Vette's Avatar
68/70Vette
First try a search. These lock problems are a pretty common problem. There's been a lot of posts on how to open a door when the latch has failed. You need to learn how to insert a screw driver down into the door opening to trip the latch.
Your passenger's latch is buggered. Go ahead and buy a replacement (~$100) and with the replacement and the photos on this forum, you can see how to place your screwdriver down into the assembly to trigger a release.
Once your latch has locked up, you need to get rid of it. That's why I advised buying a new on.
I bought new latches for my 70. No problem. However I had to buy one for my 68.....big problem. 68 is a one year different latch!
Inside the latch mechanism, are levers of soft steel 0.070 inch thick. The pivots for the levers are just simple lever holes and shafts, with no lubrication. Over the years, the shaft holes get worn open and if an interference condition occurs, the internal levers will bend. Once they bend, you can experience a lock condition.
Old Aug 2, 2010 | 12:38 AM
Father N Son's Avatar
Father N Son
My car did this before so i had to keep a coat hanger in my car for a little while, stick it in and pull on the rod.
Old Aug 2, 2010 | 04:02 PM
john roth's Avatar
john roth
Somewhere on here is write up with great pics showing you how/were to reach down along the glass with a long skinny screw driver and push on the right lever of you door opening mechanism to unlock.
I found it a few years ago and was home free in minutes. Painted the little lever yellow in case it ever happened again. Unnecessary I guess since I forgot all about it until now.
search door mechanism tech and general
JR
Old Aug 2, 2010 | 04:50 PM
Burnt71's Avatar
Burnt71
Default Good News / Bad News
Old Aug 2, 2010 | 06:03 PM
bluthundr's Avatar
bluthundr
That's exactly how I would have ended up fixing it too, with rage, brute force, and a credit card.
Old Aug 2, 2010 | 06:09 PM
thnk2mch's Avatar
thnk2mch
Yikes.
Burnt71,
I'd hate to know how you got your screen name.
Old Aug 2, 2010 | 08:30 PM
bop's Avatar
bop
Don,t feel bad my door panel looked just like yours when i finaly got my door unlocked, we should send our door panels to the museum.
Old Aug 2, 2010 | 08:41 PM
Burnt71's Avatar
Burnt71
And beer
Old Aug 3, 2010 | 10:42 PM
GUSTO14's Avatar
GUSTO14
Just posted this earlier for a similar problem... with a bit of practice it works very well and best of all... no destroyed door panels!!!
You'll need a small flashlight and a long thin straight bladed screwdriver. With the window down, reach inside the door with the screwdriver and place the flat of the blade on this lever in the lock mechanism. Use the flashlight to find the sweet spot. Strike the handle sharply with the palm of your hand and the latch will release. It may take a few tries to find the lever and to place the flat of the blade on it, but once you get the hang of it, it works every time.
I remove the latch assembly and clean them thoroughly with a good degreaser. These things get very gummed up over time with dirt and old grease and resist operating smoothly. Once you get the latch thoroughly clean, use a light coating of white grease (lubriplate) and it will give years of excellent service.
Good luck... GUSTO
Old Aug 4, 2010 | 08:10 AM
Burnt71's Avatar
Burnt71
Good luck... GUSTO
I know just what your talking about. Easy now that I lived through it
Old Aug 4, 2010 | 12:43 PM
Vesa's Avatar
Vesa
Good luck... GUSTO
http://forums.corvetteforum.com/c3-t...open-help.html
Yes, million thanks!!!
To Locked Door
