Engine Numbers
Old Aug 3, 2010 | 07:09 AM
70 Vetteman's Avatar
70 Vetteman
Default Engine Numbers
I bought a 1972 Vette Roadster 8 years ago and I knew it was a NOM car. I have since lost contact with the previous owner and I am trying to find out what motor year is in the car. I have photos when the engine was rebuilt and know it is 4 bolt mains. The reason I need to know the engine year is in Ontario Canada our government has decided that they will check classic cars for pollution equipment and it must be there and working. If the engine is a different year then the car you have the pollution equipment must be for that year of motor. I guess they are trying to get the green votes and kill our fun. We have already had people fined and made to get the equipment or the car is impounded, so beware US friends if you come to Ontario with your classics. Anyway the numbers on the engine are K115T4X and below that T91158479 or could be T91153479. I don't think it is even a Vette motor but any help is appreciated so I can get compliant before I get fined. At least my 70 big block is original so only one car to do. Second question is how do you know what polution equipment is suppost to be on a car.
Thanks 70 Vetteman
Old Aug 3, 2010 | 09:25 AM
Mike Ward's Avatar
Mike Ward
The K115T4X means that the engine was built by McKinnon Industries in St. Catherines on November 5th. The T4X is a bit of a mystery as 99% of codes that start with a T are for trucks, the remainder are a few that have a number that follows the T such as in this case. Those few went into midsize Chevrolets built in the 80s. I cannot find a specific code for T4X to narrow it further.
If you provide the block casting number and date possibly this would help.
If I were you, I'd configure the car to look like a '72 Corvette from the smog point of view and not worry about what the engine came from or trying to replicate that. Your AIM will show what smog equipment the car came with.
BTW- the law does not apply to out of province/state cars, no need to scare away our neighbours to the south. There is no need for the equipment to work, it just needs to be there.
Paul74 is the expert in this unique to Ontario issue.
Old Aug 3, 2010 | 12:03 PM
joewill's Avatar
joewill
This is exactly why some people file down the date code casting and stampings on their engine..
thanks big brother for watching over us!
Old Aug 3, 2010 | 02:40 PM
Dave J's Avatar
Dave J
What does Big Brother do if your block has been decked and the numbers are wiped out?
Old Aug 3, 2010 | 02:47 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Sends you to your room without supper.
Old Aug 3, 2010 | 03:44 PM
Mike Ward's Avatar
Mike Ward
I think the OP has been given an incorrect interpretation of the law.
Old Aug 4, 2010 | 08:02 AM
70 Vetteman
The Casting number is GM3970010 with a large K2 on the drivers side, there is no date on the passenger side where most dates are. In this area there is a small raised area with two holes that don't do anything. Any other places to look? Info I have is this block casting was used from 69 to 80 in cars. As I stated it is a four bolt main engine. As for the laws, I was just at a show Sunday and the 79 vette owner beside me just got whacked $365 dollars for side pipes no cats. He had six infractions which he was told could have been $365 for each. He also stated cars of drivers that were rude and uncooperative were impounded and must have a certified mechanic do the work to release the vehicle. Seems that the field people don't have the facts as they were checking US cars. They are accompanied by the OPP. As for the polution equipment what is the AIM?
Bryan
Old Aug 4, 2010 | 09:57 AM
Mike Ward's Avatar
Mike Ward
The lack of casting number in the usual location confirms that it's a McKinnon engine, not that this helps you much. I'm no sure where the date code is actually located, maybe somebody else might know.
The AIM is the Assembly Instruction Manual. Shows how the factory put the car together.
What part of the province are you in? Sounds much nastier than what the Ottawa folks put up with.
Old Aug 6, 2010 | 07:59 AM
70 Vetteman
I am in Smith Falls and Kingston area but the owner of the 79 was from Ottawa and that is where he got dinged going to cruise night. The assembly manual I| have from Corvette Central indicates that small block base 72 vette had an air pump but all other books from Corvette experts say the Base engine 200 HP only had TCS and canister system and of course PCV but nothing else. I have added the above so I may just way and see if I get stopped unless someone else can help with the block ID.
Thanks Bryan
Old Aug 6, 2010 | 10:44 AM
Mike Ward's Avatar
Mike Ward
Small world- we're looking for property in the Perth area.
The guy with the '79 was 'asking' for trouble, side pipes are not exactly a subtle deviation from stock. As for your AIR pump, I'd sooner believe the AIM than some guy writing a book unless he can substantiate his reasons.
Old Aug 6, 2010 | 12:02 PM
emccomas's Avatar
emccomas
"K115T4X and below that T91158479"
K = St. Catherines Engine Plant
115 = Assembly date (Nov 5th)
T4X = suffix code (unknown, but most likely a truck)
T = Tarrytown, New York assembly plant
9 = Engine year (1969, most likely late 1969 )
1158479 = VIN derivative? Looks like one too many digits
If I recall, Tarrytown, NY was producing trucks in 1969 / 1970 time frame. The 010 casting number, combined with the engine year info, would seem to indicate a 1970 application.
Here is a link to another T4X engine code discussion
http://www.z28.com/forum/engine-tech...ing-gurus.html
Old Aug 6, 2010 | 12:55 PM
Mike Ward's Avatar
Mike Ward
Ed (aka Pedro) has posted some good info. Let's say he's nailed it as a '69 truck and and we could identify the exact model that Tarrytown was building at that time. We could then find out what smog stuff the truck would have come with. This would probably be less than a stock '72 Corvette, but you equip your motor this way nonetheless..
I think you'd have a tough time trying to demonstrate all this to the Ontario smogn*zis and convince them that you're permitted to do this downgrade under the law. Why go looking for trouble?
Old Aug 6, 2010 | 04:55 PM
GD70's Avatar
GD70
Here's another site to try.
http://www.nastyz28.com/sbchevy/sblock.php
Old Aug 7, 2010 | 07:06 AM
70 Vetteman
The book is the Authentic Restoration Guide for 68 to 82 Vettes by Richard Prince with imput info from NCRS guides. Everything in it about my 70 Vette seems very accurate but who knows. I guess I will wait and see if we are one of the unlucky ones as we too are running Hooker side pipes with the new laser cut covers from CC with Singray logos and crossflags, looks impressive but you are right they do attract a lot of attention.
Thanks again
Old Aug 7, 2010 | 07:12 AM
70 Vetteman
Thank you great info. So if it is a 1969 engine then I suspect that it would be treated as a 72 car. Does anyone else have any info on required emission equipment for this car VIN 1Z67K2S50596.
Old Aug 7, 2010 | 10:17 AM
Mike Ward's Avatar
Mike Ward
You sure about the AIM calling for a smog pump?
Here is a photo album from a friend's '72 base engine 4 speed/49 state car.
http://rides.webshots.com/photo/2815...10410527duOapt
This is the most original untouched '72 I've ever seen, and has gone through the NCRS Bowtie judging program. Note the TCS, PCV and charcoal cannister hook up. No smog pump.
Old Aug 7, 2010 | 10:48 AM
BBCorv70's Avatar
BBCorv70
Could the smog pump be for cars sold in California?
California was a few years ahead of other states in that time frame.
There were some special requirements for cars sold in that state at that time.
To Engine Numbers
