Lower Radiator Hose
Old Aug 4, 2010 | 06:53 PM
Timsride's Avatar
Timsride
Originally Posted by ED79
No thanks not just yet, it is a black hard plastic extention that attaches to it so as to put more fresh air to the radiator. Thanks Ed
Thats basically what that is I have one on My 73 and it works great.
Old Aug 4, 2010 | 08:11 PM
ED79's Avatar
ED79
I'm sure that if or when I find the right material I could make one myself but until then I'll buy it. Your's for sale??? Ed
Old Aug 5, 2010 | 08:41 PM
GUSTO14's Avatar
GUSTO14
Yes you could. It's a very simple piece of material, very similar to mud-flap material that trucks use (thin conveyor belt material would also work). It is about 4" wide and therefore adds about 2 additional inches to the bottom of the spoiler. The upper part benefits from the added rigidity of having the spoiler behind it while the lower part remains flexible enough to easily go over most curbs without being damaged and still retaining its shape.
Here's another picture that shows a slightly different perspective.
The only additional cut is that there is a slight cut with a small gap in the middle that allows the extension to curve with the spoiler. It attaches with small bolts (you could certainly use pop rivets) and has two thin strips of metal on the backside of the spoiler to help retain it's shape.
Good luck...GUSTO
Old Feb 26, 2024 | 02:03 AM
Anson Chan's Avatar
Anson Chan
1st Gear
In your case, it is recommended to consider using the austenitic 201/304/430 stainless steel material
201 304 430
Old Feb 26, 2024 | 04:29 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
I'm thinking 14 years on they may have found a solution by now.
perhaps in future you look at the dates on these posts?
Well, just a thought.
