72 tail light housing
Old Aug 5, 2010 | 04:43 PM
Sully1882's Avatar
Sully1882
Default 72 tail light housing
is there a way to replace the mounting studs that are rivoted into the housing? Surely some one of you creative guys has come up with some inventive way of going about this. I really dont want to have to buy a new one since they cost over 50.00 a piece!
thanks,
Sully
Old Aug 5, 2010 | 04:53 PM
BBCorv70's Avatar
BBCorv70
thanks,
Sully
Think I just drilled out the stud from the reflector side and put in a bolt.
I seem to recall some studs broke off. Been a while since I worked on
this area. Never pass NCRS judging but holds the housing in.
Old Aug 5, 2010 | 09:54 PM
Sully1882's Avatar
Sully1882
BB that's what I was hoping to hear.... after thinking about it I was figuring I could just drill out the crappy little soft metal suds and replace with a bolt! I am glad you confirmed what I was thinking!
Old Aug 6, 2010 | 08:49 AM
hwcoop's Avatar
hwcoop
Broke all my studs when i removed mine! and was not going to pay $50. ea to replace them.
I started by drilling out the existing studs, sandblasting my housings & then tack welded 1/4" X 1" pan head machine screws on . I welded so it would be a permanent repair and because the light harness provides a ground to the housing.
I finished up by spraying with a reflective silver paint. Saved $200. that could be used for more important things
Old Aug 6, 2010 | 09:37 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Carriage bolt. I removed a broken stud on one of my '68 units and used a carriage bolt.
To 72 tail light housing
