Automatic shifter ball question
Old Aug 10, 2010 | 06:59 PM
relic1864's Avatar
relic1864
Default Automatic shifter ball question
My 76 Corvette does not have the origonal shifter ball. Its an automatic. I want to replace the shifter ball thats on it now because it is hard to press the top button down. If I order a new shifter ball and spring what do I need to do to put this back on. Does the ball just unscrew and the ball and spring come off and just put the new one back on. Or is there something special that has to be done to change it back?
Old Aug 10, 2010 | 07:02 PM
Carlos840's Avatar
Carlos840
Just unscrew and swap, there is a spring under the push button and thats it...
Old Aug 10, 2010 | 08:46 PM
my 76 ray's Avatar
my 76 ray
I don't know about your aftermarket shifter ball, but on the original you have to unscrew the button, then unscrew the ball.
Old Aug 10, 2010 | 08:50 PM
Carlos840's Avatar
Carlos840
Really, on my 76 i just unscrewed the bass and the button came off! No way to unscrew it first...
Old Aug 11, 2010 | 10:01 AM
Lon Wayne's Avatar
Lon Wayne
Default Vader Vette
Well there you go you been screwin the Bass. Why did I not think of that.
Old Aug 11, 2010 | 11:06 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Yep. Be ready to catch the spring when you unscrew the thumb button.
Old Aug 11, 2010 | 11:28 AM
Carlos840's Avatar
Carlos840
I actually meant the Ball! Im a bass player, must of had a brain fart when i typed that!
Old Aug 12, 2010 | 01:02 PM
Dantana's Avatar
Dantana
mine was all stuck together. a few choice words and some vice grips got it apart. Of course, everything was pretty well messed up by then...
To Automatic shifter ball question
