Sidepipe options
Old Aug 10, 2010 | 09:55 PM
flyinfree's Avatar
flyinfree
Default Sidepipe options
I want sidepipes. I like the 69 style however I dont really have 3k to drop. Has anyone here researched sidepipe options. Can the fiberglas 69 covers be chromed and look good. If so what is involved in that process. Can they be purchased chromed and ready to go.
What about the othe sidepipe options. I kind of like the Hooker set ups as an alternative. What are my options and what would they realistically cost. I need everything from ehaust manifolds to hangers.
Old Aug 10, 2010 | 10:18 PM
mj9311's Avatar
mj9311
http://www.mamotorworks.com/corvette-4-35.html
there a little cheaper than 3k but maybe it'll help
Old Aug 11, 2010 | 06:42 AM
MrJlr's Avatar
MrJlr
Old Aug 11, 2010 | 11:59 AM
Dantana's Avatar
Dantana
the hooker systems are great but there is a big price difference in the different finishes/materials (black, chrome, stainless). Also, the headers are one piece from engine bolt on point to the collector on the outside of the car so you will need to worm them in there. I love mine (black) but they show signs of rust every 2 years or so I have to redo them. I need to get them coated at some point. Also, the hooker systems get very hot and are in a position to burn your legs because they mount next to the car rather than underneath. I find it happens more to passengers even though I remind them every time. Remember also that you have to buy the baffles unless you want to run 4" straight pipes...
I wouldn't trade mine for any other exhaust systems at this point.
Old Aug 11, 2010 | 02:21 PM
mj9311's Avatar
mj9311
can you run them w.o baffles tho?? will it screw up the motor w.o enough back pressure??
Old Aug 11, 2010 | 02:35 PM
Corey_68's Avatar
Corey_68
yes you can them open, if you don't mind being deaf as a result.
Old Aug 11, 2010 | 02:38 PM
mj9311's Avatar
mj9311
thats awesome i was always under the impression that with little to no back pressure you would blow your motor... or maybe my father always told me that so it isnt obnoxiously loud
Old Aug 11, 2010 | 02:44 PM
Corey_68's Avatar
Corey_68
most race cars run open headers which would work, but full time of the street would get old quick IMO.
I tried it and no way could I live with it off the track. Rear exit straight pipes are one thing, but side pipes that exit 2ft from you head is another.
Old Aug 11, 2010 | 02:49 PM
mj9311's Avatar
mj9311
understandable... i have the motor out of mine now and im stroking it out and all that fun stuff how hard was it to snake them in since there 1 piece and what kind of power increase did u see from them cause i have hooker headers now with 3'' pipe muffler just curious on the power and the sound quallits if its worth it to spend 1300 on them
Old Aug 11, 2010 | 02:55 PM
mj9311's Avatar
mj9311
and did they come with the baffles thanks the info is a big help
Old Aug 11, 2010 | 03:10 PM
IrishJoker's Avatar
IrishJoker
Install a set of heat shields mine work great and look great. The Hookers setup isn't hard at all if you have access to a lift. I admit the shields cost me an extra $400.00 in stainless (my whole setup is stainless as well). When I ordered my sidepipes I went ahead and ordered Hooker's baffles, they offer two that will fit.
"Sweet Thunder" also makes sets that will work.
Here's a picture of my setup.:
Old Aug 11, 2010 | 03:13 PM
Earthquake Driver's Avatar
Earthquake Driver
From: I buy all my days at the same place where the girl sells her nights
http://www.jegs.com/p/Patriot-Exhaus...52602/10002/-1
Old Aug 11, 2010 | 03:50 PM
samh's Avatar
samh
Hooker all the way!
I'm not really a big fan of the shields, at least not until I burn my leg .
For my solution, I have two sets of side pipes; I put the chrome pipes on for show, and run ceramic coated pipes normally. There a huge heat difference between the two types of pipes! Both have the 2.5 inch Sweet Thunder "SideCannon" baffles in them. At the track, I run straight pipes...loud as hell, but music to my ears. The track spectators don't seem to mind either!
Not your normal setup, I agree, but it works for me.
Here's a shot with the ceramic pipes:
Old Aug 11, 2010 | 03:57 PM
smon's Avatar
smon
check out jet-hot for their hooker sidepipes. Great deal
Sean
Old Aug 11, 2010 | 04:50 PM
Corey_68's Avatar
Corey_68
you can order the hookers with reverse flow mufflers but
1) they will be quiet
2) kill horsepower like no other.
I highly, HIGHLY recommend STS baffles http://www.spiralturbobaffles.com/corvette.html they sound great and will no rob you of power. The owner of the company is member here and also recommend Dean's covers, they too are a MUST. He's also a member here. http://www.steelshields.com/
My car with STS baffles.
Old Aug 12, 2010 | 08:23 PM
TimAT's Avatar
TimAT
I ran STS baffles until I saw this video:
Yanked 'em out. No problems with the baffles- they are a very good well made product. I've driven the car maybe 300 miles in the last 2 years so noise is not a factor to me. Drive it to a cruise and home. If the cruise is over 50 miles, I trailer it. $7.50 a gallon for gas, feeding a BB with 4:11 gears, I need to have some cash for important things like beer.
FWIW: Ol' Red sounds pretty much like the 69 toward the end of the video.
Old Aug 12, 2010 | 08:37 PM
samh's Avatar
samh
Man I can TOTALLY relate (tho I still run baffles except at the track)...but $7.50 a gallon!? Wow! Gots to have beer money!
To Sidepipe options
Old Aug 13, 2010 | 09:12 AM
TimAT's Avatar
TimAT
Yep, $7.50. VP110 octane gas ain't cheap. Smells nice at the end of the sidepipes too. That's what I get for having 12.5 compression.
Old Aug 13, 2010 | 11:39 AM
gprox's Avatar
gprox
3rd Gear
My '76 came with the chrome hooker sidepipes...they looked great and sounded great but they're dangerously hot and had many bad burns on folks getting out of the passenger side not being familiar with the hazard. They also only lasted a few years of daily driver (no rain) and they would rust out at the inner meeting point of the four tubes into the collector where the plating didn't seem to flow well. I finally replaced them with the fiberglass covers painted aluminum with gloss top coat and ran standard tailpipe from the exhaust manifolds down the center of the car, stock location, through the frame cutouts to short turbo mufflers and then bend 90 degrees to exit at the sidepipe cover spill locations. It looks like a functional sidepipe system without the heat, cost, and need for periodic replacement. I can change the mufflers at will for standard muffler shop costs and it flows and sounds great
Old Aug 13, 2010 | 04:11 PM
CTVETTE78's Avatar
CTVETTE78
Now about posting a photo of your setup?
