Sidepipe options
Old Aug 23, 2010 | 04:37 AM
CRAIGVETTE's Avatar
CRAIGVETTE
Veteran: Coast Guard
Senior Member
Cruise-In V Veteran
Originally Posted by gprox
My '76 came with the chrome hooker sidepipes...they looked great and sounded great but they're dangerously hot and had many bad burns on folks getting out of the passenger side not being familiar with the hazard. They also only lasted a few years of daily driver (no rain) and they would rust out at the inner meeting point of the four tubes into the collector where the plating didn't seem to flow well. I finally replaced them with the fiberglass covers painted aluminum with gloss top coat and ran standard tailpipe from the exhaust manifolds down the center of the car, stock location, through the frame cutouts to short turbo mufflers and then bend 90 degrees to exit at the sidepipe cover spill locations. It looks like a functional sidepipe system without the heat, cost, and need for periodic replacement. I can change the mufflers at will for standard muffler shop costs and it flows and sounds great
Sounds like a great idea! I too would love to see pics of your setup from the exterior, as well as pics from under the car.
Old Aug 23, 2010 | 09:11 AM
gprox's Avatar
gprox
3rd Gear
We've got a few days of bad weather floating over us in the Northeast...once it clears I'll get the car outside and see if I can get some photos
Old Aug 25, 2010 | 08:38 AM
jersey68l36's Avatar
jersey68l36
Brought my '68 in '72, the first set of Hooker side mounts were installed, in the Fall of that year. Presently just brought my third pair, and running 2.25 id Sweet Thunder inserts.
IMHO, no single bolt-on compared to the horsepower per dollar increase of those header side pipes.
Old Aug 25, 2010 | 10:21 PM
CRAIGVETTE's Avatar
CRAIGVETTE
Senior Member
Cruise-In V Veteran
Thanks, looking forward to seeing your pics when the weather cooperates
