76 A/C Compressor Mount Bracket
Old Aug 13, 2010 | 11:01 AM
a-alshebli's Avatar
a-alshebli
Default 76 A/C Compressor Mount Bracket
Hello,
I am planing to buy a new A/C Compressor Mount Bracket for my Stock Compressor. But I found that there are 2 type of Bracket some for 76E and other for 76L How could I know if my car need the 76E Bracket or 76L ?
Thanks,
Abdull
Old Aug 13, 2010 | 11:19 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
For the bracket you want, early cars had the A6 compressor and essentially the same mounting hardware used 68-76E. Late 76s (May 76 and later) got the R4 radial compressor and the same hardware as the 77 up cars.
When was your 76 assembled? What type of compressor do you have?
Old Aug 14, 2010 | 05:51 AM
a-alshebli's Avatar
a-alshebli
Really I don't know when it was assembled. But I know it have the A6 compressor.
Old Aug 14, 2010 | 07:36 AM
Go Vette Go's Avatar
Go Vette Go
2024 C3 of the Year Finalist- Unmodified
St. Jude Donor '10-'11, '15, '19
If your compressor is long - about 12" with the pulley/clutch assembly, you have an early. If you compressor is about the size of your alternator, you have a 76 late.
I may have all the brackets for both.
John
Old Aug 14, 2010 | 09:53 AM
a-alshebli's Avatar
a-alshebli
Thanks John,
Yes I have the A6 compressor which is the early one.
Many thanks,
Abdull
To 76 A/C Compressor Mount Bracket
