Backfires and misses
Old Aug 22, 2010 | 06:07 PM
endoman's Avatar
endoman
Default Backfires and misses
I installed a Crane XR-i points replacement several years ago. Recently, after a short full throttle blast, the car started running rough. I checked the timing today and it was erratic. The dwell was also 16. Could the module be bad. Any way to test them?
Rob
Old Aug 23, 2010 | 10:34 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I'm guessing you slipped a tooth or two on the timing set.
Old Aug 26, 2010 | 12:59 PM
Lon Wayne's Avatar
Lon Wayne
Default Lon Wayne
Rob
Maybe the dist. spun in heavy take off ?
My module went bad in my 75 it was eratic till one time it died and stayed dead, it was the center copper wire on the coil it had broken off of the connector .
To Backfires and misses
