How do you remove the spare tire?
Old Aug 22, 2010 | 08:19 PM
damifino's Avatar
damifino
Cruising
Default How do you remove the spare tire?
I'm trying to remove the spare tire on a 71 coupe. Not real sure just how it comes off. Any tips greatly appreciated. I was told there may be a packet of information on top of the original gas tank that would have details specific to this vette and I would have better access if the spare was removed. Also I noticed a place for a key to be inserted that is under the rear bumper on the drivers side could this be an alarm system? Thanks in advance.
Old Aug 22, 2010 | 08:23 PM
wan2run's Avatar
wan2run
I assume you're referring to the spare tire lock. Unlock it, remove the lock, and you should be able to unhook the lower portion of the tub.
Old Aug 22, 2010 | 10:37 PM
7T1vette's Avatar
7T1vette
Once lock is removed, use jack/lug wrench to loosen the hex head bolt that is under the lock. Then take the other end of the jack handle and stick it in the square hole on the lower part of the tub. Use the handle to leverage the tub up and off of that retainer bolt and lower the tire and lower tub to the ground. Now you can take the tire out of the tub.
Old Aug 22, 2010 | 11:50 PM
65GGvert's Avatar
65GGvert
But you've still got a long way to go to get to the build sheet. If you don't know how to lower the spare, you really should get some knowledgable help to get above the gas tank to the build sheet.
Old Aug 23, 2010 | 09:53 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by damifino
...I was told there may be a packet of information on top of the original gas tank that would have details specific to this vette and I would have better access if the spare was removed...
There is no "packet" of information on the fuel tank. You might find evidence of a single sheet of paper - a copy of the Corvette order copy for your car -- called a build sheet or tank sticker. Part of this one is visible:
After nearly 40 years, it may no longer be there, or what you find might be incomplete or illegible. Personally, it's not worth the time and effort to drop the fuel tank to find out.
Owner's manual shows you how to lower the spare tub.
Old Aug 23, 2010 | 10:10 AM
thread baron's Avatar
thread baron
If you are only interested in the build sheet I would recommend pulling to the side the rubber "boot" (not sure what it is called) around your gas cap. You will be able to look at the top of your gas tank with a good flaslight and see if anything is left of the sheet. The locations are pretty much the same as Mike's picture (which shows the rubber boot also) above.
It is tight but would save you the trouble of taking out your tank.
To How do you remove the spare tire?
