Spectre Radiator Hoses
Old Aug 28, 2010 | 09:22 PM
a-alshebli's Avatar
a-alshebli
Default Spectre Radiator Hoses
Hi,
I am planning to buy Lower and upper Radiator Hoses ( Brand: Spectre ) for my 76 vette. There are no modification on the car. Could I install these hoses ? If, yes what is the best Length and inside Diameter for the lower and upper hoses.
Many thanks,
Abdull
Old Aug 29, 2010 | 12:16 AM
GPGG70's Avatar
GPGG70
Originally Posted by a-alshebli
Hi,
Many thanks,
Abdull
Hi abdull,
Not sure abouit your 76 but they should be very close. I have the summit racing brand but also heard the spectre hoses are good also. My hose came as a kit and it will fit most size radiators. I bought the 24inch lenght hose and cut it down to size with a saw then filed down the hose ends smooth. So far no leaks.
Hope this helps.
Old Aug 29, 2010 | 03:33 AM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
That brand is very cheap CHinese crap. Get Goodyear hoses or similar.
Old Aug 29, 2010 | 04:11 AM
a-alshebli's Avatar
a-alshebli
Originally Posted by GPGG70
Hi abdull,
Hope this helps.
Thanks GPPG70,
I will go as you went. I will buy a summit racing hoses. Thank you again
Abdull
Old Aug 29, 2010 | 04:14 AM
a-alshebli's Avatar
a-alshebli
Thanks SanDiegoPaul for the advice. I will go with summit Brand.
Abdull
Old Aug 29, 2010 | 05:19 AM
FlyViper's Avatar
FlyViper
Yep, my upper lasted about 4 months before leaking. I now have the stock goodyear hoses...should have done that in the first place.
To Spectre Radiator Hoses
