There may not be any written instructions. The AIM has useful diagrams. Most people start in the rear and work forward. At the plant, the front carpets were installed last after the water test.
Hi DJ,
I agree that the wheel well arches are the toughest.
You also need to be very careful when you plan the cuts and flaps for the seat tracks.
It helps a lot if you can get the special scissors the trim shops use... the one that has a dial you set to CUT or UN-CUT.
Regards,
Alan
